How to export shortcuts into a nice textformat?
All  1-3  4-5
9656.4 In reply to 9656.3
Seems Notepad++ has this sort of formats(except PDF)
so you can reload to Excel...
9656.5 In reply to 9656.1
Hi Lordfox, you can use Excel for that.
First go to moi.ini and select the entire [Shortcut Keys] section and use Ctrl+C.
Inside Excel select cell A1 and use Ctrl+V to paste in the text.
Now stretch out column A (so it is easier to go to the B column), then go to cell B1 and put in this: =LEFT(A1,FIND("=",A1)-1)
That will extract out the text before the first = sign. Select the cells from B1 downwards to your last row and use Fill > Down. This has now extracted the "Key" part of the shortcut key into its own column.
Now in cell C1 put in this: =RIGHT(A1,LEN(A1)-LEN(B1)-1)
That extracts the "Command" part of the text. Select the cells from C1 downloads to your last row and use Fill > Down.
Now hide Column A and you should have 2 separated columns that you can print out.
Show messages: All  1-3  4-5
