Script advice?
All  1-5  6-20
965.6 In reply to 965.5
Imagine a cube sliced into 2 parts by the script. That's all it is, just a quick convenience function to slice and dice an object up real fast. One use for it is if you have a model with internal parts and want to get a quick look at something inside - split the model, take a quick look, hit undo and you're back to where you started. Another use might be to make a quick cross-section of a model or to chop a section out of a model by splitting the model in 2 places and deleting the section.
Hope that helps!
Paul
965.7 In reply to 965.6
Thx for the explanation
I will try it :)
PS You have not written what we must write for the Angle in column of the Shortcut
Pss an you must write for the first for example
Alt+X QuickSplit_XYZ X
Alt+Y QuickSplit_XYZ Y
Alt+Z QuickSplit_XYZ Y
becauce I have written QuickSplit_XYZ X (y or Z) and nothing work !!! :)
EDITED: 30 Sep 2007 by PILOU
965.8 In reply to 965.7
Hi Pilou.
"because I have written QuickSplit_XYZ X (y or Z) and nothing work !!! :)"
Good point! :) I should have been more clear -- it's:
QuickSplit_XYZ X
QuickSplit_XYZ Y
QuickSplit_XYZ Z
For the Angle script there is no parameter to enter. The angle is chosen by where you place your 2 points on the model.
Paul
PS --
After playing around with QuickSplit_Angle for awhile I realized Pilou was thinking "angle as defined by a specified angle". Turns out there is a way to do that with this script:
Pick your object, hit your hotkey, pick the location you want the split to run thru, go to the angle box at the bottom of the gui and enter a number for the amount of precision you need for the angle, that turns on snapping set to that precision. Then pick your 2nd point on the model, after moving the pointer around until you get the angle you want. The split will be done at the specified angle. In other words, if you want a split at 45 degrees, enter 5 in the angle box and snapping will happen at increments of 5 degrees. If you want 22.5 degrees, type in 0.5, snapping sets to 0.5 degree increments.
The more I use MoI, the more I realize how well thought out Michael's design is!
EDITED: 30 Sep 2007 by AIRGLASS
965.9 In reply to 965.8
That works fine :)
But I dont understand why you have 2 scripts?
Split_Angle with Snap Direct enable can make the same than QuickSplit_xyz (and more of course) :)
So I have erased QuickSplit_xyz and keept Split_Angle who is very useful indeed :)
965.10 In reply to 965.9
Yes, I realized that too, after I used it awhile.
The Angle script is all that's needed. :) Oh, well, learned a little more about MoI's scripting in the process...
Paul
965.11 In reply to 965.10
hi Michael
Does the SPLIT script work with MoI 5.0 beta Apr-8-2023 to obtain section like the example ?
Or have you planned a "section view" function ?
thanks
Christian
EDITED: 10 Aug 2023 by CHRI
Size: 182.1 KB, Downloaded: 50 times, Dimensions: 794x663px
965.12 In reply to 965.11
Hi Chri,
I'm not familiar with the "split" script, can you show me where that is located?
But you can use the regular boolean difference command to make a cut like that.
Draw in your parting line like this:
Select the objects and run Construct > Boolean > Difference. Then select the line at the cutting object:
I would like to have a section view function but I'm not sure when it will happen.
965.13 In reply to 965.11
You can also use Construct > Curve > Project to project a line onto objects which will generate section cut curves:
965.14 In reply to 965.13
Hi Michael
Thanks for your quick answers
you can find the link here :
http://kyticka.webzdarma.cz/3d/moi/
function : Quick Splitting
beginning of the discussion
http://moi3d.com/forum/index.php?webtag=MOI&msg=965.1
boolean difference is the function i have used
but we have to do as many Boolean operations as there are parts to be cut
the result is nice and it's a 3D section
you can also use Construct > Curve > Project to project a line onto objects which will generate section cut curves:
this function is simple and fast but the result is now a 2D section
it would be nice to cut a group of parts with a plan or a line in one time then select between the 2 groups which one should be masked.
christian
EDITED: 14 Apr 2023 by CHRI
Size: 50.5 KB, Downloaded: 24 times, Dimensions: 479x609px
965.15 In reply to 965.14
Hi christian,
Sorry, I'm not understanding this part. You can select all the objects and do just one boolean, you don't need to do them one at a time.
965.16 In reply to 965.15
hi Michael
you are right Michael
i made a mistake, i have used merge function instead diff function
it works fine with merge function
Sorry.
965.17 In reply to 965.16
Hi
an example cut by polyline ( gif file)
Thanks Michael
Size: 243.9 KB, Downloaded: 36 times, Dimensions: 441x383px
965.18 In reply to 965.17
A simple Boolean Diff Box don't make the trick ?
so here as you have a polyline...an extruded polyline ;)
EDITED: 15 Apr 2023 by PILOU
965.19 In reply to 965.18
hi Pilou
You're right, I didn't think you could simply subtract a solid; it was too easy!
In MOI, everything is easier than in other software!
Bonjour Pilou
Tu as raison, il ne m'est pas venu a l'esprit que l'on pouvait tout simplement soustraire un solide; trop simple
Dans MOI, tout est plus facile que dans les autres logiciels !
Merci
christian
EDITED: 16 Apr 2023 by CHRI
965.20 In reply to 965.19
Normally a polyline under (upper) the volumes should make also the Boolean Diff...
but use "planes" help a little more to see where the cut will be made and also the prog in complexe cases! :)
EDITED: 16 Apr 2023 by PILOU
Show messages: All  1-5  6-20
