Script advice?
All  1-14  15-20
965.15 In reply to 965.14
Hi christian,
> boolean difference is the function i have used
> but we have to do as many Boolean operations as there are parts to be cut
> the result is nice and it's a 3D section
Sorry, I'm not understanding this part. You can select all the objects and do just one boolean, you don't need to do them one at a time.
965.16 In reply to 965.15
hi Michael
you are right Michael
i made a mistake, i have used merge function instead diff function
it works fine with merge function
Sorry.
965.17 In reply to 965.16
Hi
an example cut by polyline ( gif file)
Thanks Michael
Size: 243.9 KB, Downloaded: 36 times, Dimensions: 441x383px
965.18 In reply to 965.17
A simple Boolean Diff Box don't make the trick ?
so here as you have a polyline...an extruded polyline ;)
EDITED: 15 Apr 2023 by PILOU
965.19 In reply to 965.18
hi Pilou
You're right, I didn't think you could simply subtract a solid; it was too easy!
In MOI, everything is easier than in other software!
Bonjour Pilou
Tu as raison, il ne m'est pas venu a l'esprit que l'on pouvait tout simplement soustraire un solide; trop simple
Dans MOI, tout est plus facile que dans les autres logiciels !
Merci
christian
EDITED: 16 Apr 2023 by CHRI
965.20 In reply to 965.19
Normally a polyline under (upper) the volumes should make also the Boolean Diff...
but use "planes" help a little more to see where the cut will be made and also the prog in complexe cases! :)
EDITED: 16 Apr 2023 by PILOU
Show messages: All  1-14  15-20
