Script Runner
9638.1
I make script, hotkey and command runner with fuzzy filter and history. Is it possible to select items from a list using not only mouse, but the keyboard?
Size: 1.3 MB, Downloaded: 77 times, Dimensions: 308x542px
9638.2 In reply to 9638.1
Hi Quaritexa,
A dialog window that has keyboard focus will get a chance to handle all keystrokes by implementing OnKeyDownEvent and/or OnKeyUpEvent script functions on it. Check out ShortcutKeyDialog.htm for an example.
9638.3 In reply to 9638.2
How to define buttons is understandable. And how do you change the focus on the menu items?
9638.4 In reply to 9638.3
Hi Quaritexa,
I'll probably need some more detailed information on what you're doing. Are you using <moi:MenuItem> elements there and you want some of them to have a highlighted background?
If so you could try switching to <moi:ListItem> elements instead, a <moi:ListItem> inherits from StateButton which means it has a .value property and if that is set to true it will display with a different state.
A <moi:MenuItem> element does not have a built in way to display a different background like that, it only has a .checked property for showing a checkmark or not.
