Objects with touching corners no longer solid
All  1-2  3-5
9624.3
Yep, this happens. Probably because the central point is going crazy with two boolean ops on top of eachother. Might be a problem with the operation and not the program per se. You can recreate this even if you union the two boxes and the base instead of subtracting them. This might not be a watertight volume as the vertical edge in the middle is being essentially removed by the boolean sub. Might be wrong though!
9624.4
> Send your 3DM files for test!
Sorry, I thought this was trivial. Here it is. :)
Oh, right, that's even easier and it leads to the same result.
9624.5 In reply to 9624.1
Hi Andre, so that is not a bug exactly, it's more of a type of situation that you should avoid.
To have a well formed solid, each edge of the solid must be connected between only 2 surfaces.
In your case the location here there are 4 surfaces touching each other at a single edge:
That forms what is called a "non-manifold" edge in that location. That's problematic for various reasons, it basically makes points on that edge ambiguous for volume oriented calculations.
So you would need to give either a little bit of space or some overlap between your cutting pieces rather than having them exactly graze each other in that manner.
Show messages: All  1-2  3-5
