Color of objects projected on surface
All  1-2  3-5
9615.3 In reply to 9615.2
thanks for that. I cross checked and the entry is set to "y". I changed either and the selected red colored curve is black on the surface when projected.
Best regards,
Axel
9615.4 In reply to 9615.3
Hi Axel, yes if you set GeneratedObjectsInheritStyle=n then the generated object (for project it's the projected result) should get the active style applied to it. The active style is the one that has the outline around its color swatch in the scene browser.
I've fixed the bug for the next v4 beta so that if GeneratedObjectsInheritStyle=y (which is the default), the projected curve will inherit the style of the input curve rather than inheriting the style of the target surface like it does currently.
And just in case someone did prefer it I've added in an additional moi.ini setting which will keep the buggy Project style behavior since it's been that way for quite a while.
9615.5 In reply to 9615.4
thanks for that! Much appreciated.
Best regards,
Axel
Show messages: All  1-2  3-5
