Hi Axel, do you have a template file set up under Options dialog > General section > "Template file" ?
If so then the styles from that file are used as your defaults. You can either clear out the template file setting so the template file will not be used anymore, or you can open up the template file, edit the styles there, and resave it.
Let me know if that wasn't it.
