Node help
All
1-4
5-8
Barry-H
8 Dec 2019 (5 of 8)
9608.5
In reply to
9608.4
no the block needs to be on the 45 degree axis when rotated.
Barry
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
8 Dec 2019 (6 of 8)
9608.6
In reply to
9608.5
So Maybe with this Orient Node before rotation we can rotate anything on its own axe
(defined by 2 points XYZ (Top / Bottom)
Not yet tested but that must maybe work :)
http://moiscript.weebly.com/transform.html#bibeorient
Following is just one point (Bottom)
EDITED: 8 Dec 2019 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Barry-H
8 Dec 2019 (7 of 8)
9608.7
In reply to
9608.6
by adding a pivot line and using the getCrvSFrame works see photo.
Barry
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
8 Dec 2019 (8 of 8)
9608.8
In reply to
9608.7
Excellent! Bravo! So the simulation of the Transform / Rotation / Rotate Axis
More simple than my 2 points Top Bottom :) (that i have never found! )
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-4
5-8
