Node help
All  1-2  3-8
9608.3 In reply to 9608.2
rotating about the X,Y and Z is not my problem. The axis of rotation is around the pivot pin which is at 45 degrees.
In the photo I show a block and pivot pin square to the X,Y and Z axis so rotating around the pivot pin is no problem
but the second block & pivot pin are at an angle at 45 degrees and to achieve a rotation around that axis is my issue.
Barry
9608.4 In reply to 9608.3
It's not the same than this...
Put your object on the X Axe
Make a first rotation around X of any ° wanted
then result with a second rotation around Z of 45 ° ?
9608.5 In reply to 9608.4
no the block needs to be on the 45 degree axis when rotated.
Barry
9608.6 In reply to 9608.5
So Maybe with this Orient Node before rotation we can rotate anything on its own axe
(defined by 2 points XYZ (Top / Bottom)
Not yet tested but that must maybe work :)
http://moiscript.weebly.com/transform.html#bibeorient
Following is just one point (Bottom)
EDITED: 8 Dec 2019 by PILOU
9608.7 In reply to 9608.6
by adding a pivot line and using the getCrvSFrame works see photo.
Barry
9608.8 In reply to 9608.7
Excellent! Bravo! So the simulation of the Transform / Rotation / Rotate Axis
More simple than my 2 points Top Bottom :) (that i have never found! )
Show messages: All  1-2  3-8
