align 3d view to surface
All  1-2  3-9
9607.3 In reply to 9607.2
I write this code:
/* Align 3D view to surface */ script: var vp = moi.ui.mainWindow.ViewPanel.getViewport('3D'), cp = moi.view.getCPlane(); moi.view.setCPlaneInteractive(); var vt = moi.ui.mainWindow.viewPanel.getViewport('top'); vp.setCameraAndTarget(vt.cameraPt, vt.targetPt); vp.Projection = 'Parallel'; moi.view.setCplane(cp, true, true);
But I'm not sure the code is correct.
And I don't know how to set right camera rotation.
EDITED: 7 Dec 2019 by QUARITEXA
9607.4 In reply to 9607.3
Hi Quaritexa, it's pretty close. One thing is put the script: label at the very start, then you can put the /* */ comment after that.
For rotation maybe the only way currently is by the tiltAngle property.
I'll see about adding in a new method that takes a camera, target, and also an "up" direction vector. I think you can get a viewport's "up" direction from cameraFrame.yaxis but there isn't a way to set it directly. I think the tiltAngle should be an angle value that is how much the current up direction is rotated away from the world z axis.
9607.5 In reply to 9607.3
Try this one, it seems to be very slightly off I'm not sure why at the moment:
script: /* Align 3D view to surface */ var vp = moi.ui.mainWindow.ViewPanel.getViewport('3D'), cp = moi.view.getCPlane(); moi.view.setCPlaneInteractive(); var vt = moi.ui.mainWindow.viewPanel.getViewport('top'); vp.targetPt = vt.targetPt; vp.setAngles(vt.upDownAngle, vt.leftRightAngle, vt.tiltAngle); vp.Projection = 'Parallel'; moi.view.setCplane(cp, true, true);
9607.6 In reply to 9607.5
With this script the 3D view differs from the top view:
9607.7 In reply to 9607.6
Hi Quaritexa, I think the problem is the target point on the 2D views is not used for anything and so is not getting set. So get the target point through some other way instead of from the top view.
For the angle getting the tilt angle from the Top view and setting it as the 3D view's tilt angle seems to work, try this one:
script: /* Align 3D view to surface */ var vp = moi.ui.mainWindow.ViewPanel.getViewport('3D'), cp = moi.view.getCPlane(); moi.view.setCPlaneInteractive(); var vt = moi.ui.mainWindow.viewPanel.getViewport('top'); vp.setCameraAndTarget(vt.cameraPt, moi.view.getCPlane().origin); vp.tiltAngle = vt.tiltAngle; vp.Projection = 'Parallel'; moi.view.setCplane(cp, true, true);
9607.8 In reply to 9607.6
Hi Quaritexa, ok so yes the problem is that when setting the cplane the ortho view's target point did not get updated. MoI does not use the target point on the Top/Front/Right views for anything so that's why it went previously unnoticed.
I've fixed that now for the next v4 beta and also I've added in an optional additional parameter to vp.setCameraAndTarget() so it can take an "up" direction vector to set the view rotation around the camera->target line. So that will be an additional way to control it.
9607.9 In reply to 9607.7
Thank you very much, Michael. That's exactly what I need.
That's how it works:
EDITED: 8 Dec 2019 by QUARITEXA
Size: 1.9 MB, Downloaded: 131 times, Dimensions: 974x696px
Show messages: All  1-2  3-9
