Some questions about the Freehand Sketch tool
All  1-5  6-13
9606.6 In reply to 9606.5
Quasi automatic CPplane
This last one is some cool! :)
PS
CPlane's Script above...Not Undoable ?
EDITED: 6 Dec 2019 by PILOU
9606.8 In reply to 9606.7
Hi Pilou, you can right-click on the View > CPlane button to reset the cplane to the default world location. Or if you want to have it on a shortcut key put:
script: moi.view.resetCPlane();
9606.9 In reply to 9606.8
Thx for the precision! ;)
Added to the French site :)
http://moiscript.weebly.com/plan-aux.html
9606.10 In reply to 9606.7
Hi Pilou, or this variation will work as a toggle, if you use the same shortcut a second time it should reset it:
script: /* Set cplane to selected face or reset on second use */ var faces = moi.geometryDatabase.getSelectedObjects().getFaces(); var was_set = false; if ( faces.length == 1 ) { var f = faces.item(0); var cp = moi.view.getCPlane(); var vm = moi.vectorMath; if ( f.isPlanar ) { var p = f.planarFrame; if ( !(vm.pointsAreEqual(p.origin,cp.origin) && vm.pointsAreEqual(p.xaxis,cp.xaxis) && vm.pointsAreEqual(p.yaxis,cp.yaxis)) ) { moi.view.setCPlane( p ); was_set = true; } } } if ( !was_set ) moi.view.resetCPlane();
9606.11 In reply to 9606.10
Excellent! Added! :)
9606.12
Ooh, I like this script !
9606.13 In reply to 9606.10
Perfect!
Show messages: All  1-5  6-13
