Some questions about the Freehand Sketch tool
All  1-3  4-13
9606.4
Hello Michael, thank you for another lighting fast reply.
Thank you for the shortcut, this makes total sense. Is there an official place somewhere listing all these script classes, and maybe even an inventory of useful commands like this one ? Sure enough it would help power users quite a bit (as opposed to having to ask here on the forum). This page could even be accessible directly from the Shortcut Keys option panel for instance.
On my end I am currently putting the finishing touches to a floating panel grouping all my needed commands using <moi:LabelButton command="commandname"></moi> tags, in a simple index.htm called through moi.ui.createDialog. Also with a search box, meaning that all tools are just two keystrokes away (for instance typing "tr" filters for Trim) :
So naturally I'd be curious to know if there a way to call a complex command like this "sketch repeat" script from the html code. This is what I meant by appending it to a button, if that makes sense :) This would basically allow me to store custom commands without necessarily having to assign them to KB shortcuts.
[edit] Ha, nevermind ! Found it : <moi:LabelButton onclick="scriptgoeshere"></moi:LabelButton>
Lastly a follow-up question on CPlane : is there a clever way to select a surface, then click a button/run a command and have the CPlane be instantly placed on there and aligned to said surface ? As opposed to having to launch CPlane and then picking the center point and setting the orientation manually each time.
"Snap to locked objects" turned off is excellent, that does it indeed :)
Thanks !
EDITED: 5 Dec 2019 by PIOR_O
9606.5 In reply to 9606.4
Hi Pior,
There is a collection of scripts used in buttons in the help file here:
http://moi3d.com/3.0/docs/moi_command_reference11.htm#shortcutkeys
And there are some other frequently requested ones collected here:
http://kyticka.webzdarma.cz/3d/moi/
> panel for instance.
In the future I would like to make an online "script repository" that would hold a bunch of scripts listed in different categories and have a browser for them built into MoI but there will be a lot of work involved in making that so I'm not sure when it will be able to happen.
> to KB shortcuts.
Yes, on a <moi:CommandButton> element instead of having a command="commandname" attribute instead put in an onclick="" event handler attribute which can contain general script code. So for the sketch repeat it would look like this:
<moi:CommandButton onclick="moi.ui.sidePane.RepeatCheckbox.value = true; moi.command.execCommand( 'SketchCurve' );">Button label</moi:CommandButton>
(Looks like you found that already...)
A couple of v4 betas back there were some new methods added to faces that allow scripts to retrieve information on the face so it is possible to do that. Here's a script that will set the cplane to a selected planar face:
script: /* Set cplane to selected face */ var faces = moi.geometryDatabase.getSelectedObjects().getFaces(); if ( faces.length == 1 ) { var f = faces.item(0); if ( f.isPlanar ) { moi.view.setCPlane( f.planarFrame ); } }
Hope that helps!
9606.6 In reply to 9606.5
Quasi automatic CPplane
This last one is some cool! :)
PS
CPlane's Script above...Not Undoable ?
EDITED: 6 Dec 2019 by PILOU
9606.8 In reply to 9606.7
Hi Pilou, you can right-click on the View > CPlane button to reset the cplane to the default world location. Or if you want to have it on a shortcut key put:
script: moi.view.resetCPlane();
9606.9 In reply to 9606.8
Thx for the precision! ;)
Added to the French site :)
http://moiscript.weebly.com/plan-aux.html
9606.10 In reply to 9606.7
Hi Pilou, or this variation will work as a toggle, if you use the same shortcut a second time it should reset it:
script: /* Set cplane to selected face or reset on second use */ var faces = moi.geometryDatabase.getSelectedObjects().getFaces(); var was_set = false; if ( faces.length == 1 ) { var f = faces.item(0); var cp = moi.view.getCPlane(); var vm = moi.vectorMath; if ( f.isPlanar ) { var p = f.planarFrame; if ( !(vm.pointsAreEqual(p.origin,cp.origin) && vm.pointsAreEqual(p.xaxis,cp.xaxis) && vm.pointsAreEqual(p.yaxis,cp.yaxis)) ) { moi.view.setCPlane( p ); was_set = true; } } } if ( !was_set ) moi.view.resetCPlane();
9606.11 In reply to 9606.10
Excellent! Added! :)
9606.12
Ooh, I like this script !
9606.13 In reply to 9606.10
Perfect!
Show messages: All  1-3  4-13
