Hollow Octahedron
All  1  2-4
9601.2 In reply to 9601.1
Have you an image of what do you want exactly because Goolge images gives a lot of different things for "Hollow Octahedron"! :)
So what is yours ?
9601.3 In reply to 9601.1
Hi shamus, probably the easiest way is to start with using Draw curve > Rect to draw a square. Then use Construct > Extrude with the "To point" option to make a Pyramid solid from the square. Then use Transform > Mirror to make a mirrored copy of the pyramid along its base line. Next select both pyramids and use Construct > Boolean > Union to combine them together into an octahedron. To hollow out the interior of the octahedron select it and use Construct > Offset > Shell and enter in your desired wall thickness.
Let me know if you get stuck on any of these steps.
9601.4 In reply to 9601.1
You can also find a bunch of pre-made geometric shapes on grabcad.com, like this one:
https://grabcad.com/library/basic-geometric-shapes-3d-1
Also check out this page which has a bunch of polyhedron objects in 3DM format that you can download and import into MoI:
http://www.rhino3d.nl/pythposter/pyth3dm-eng.html
Show messages: All  1  2-4
