Corners Point & Repeat
All  1-2  3-5
96.3 In reply to 96.2
< so that you can hold down the Ctrl key when you click to make a corner point
Cool :)
It you take a cuve with may curve points / Show Points / select one point/ Add Corner point (over this last one)
is this corner point delete the previous curve point selected? (there is not a doubloon? )
EDITED: 11 Sep 2006 by PILOU
96.4 In reply to 96.3
No, Add point will only add in a new point, it won't delete or change any existing points.
It would be difficult to get the point directly on top of the old one, because there shouldn't be a snap enabled on the old point.
If you want to change an existing point to a corner point, you will have to delete the old point and then insert a new corner point.
96.5 In reply to 96.4
Thx That's more clear :)
Show messages: All  1-2  3-5
