Help with Fillet problems and possible workaround :)
All  1-8  9
9596.9 In reply to 9596.7
Hi sep086,
> So from my understanding I will try to have shapes as clean as possible before filleting.
Yes filleting is a pretty sensitive operation and it does not take much to get it messed up. It's particularly good to have your initial curve structure to be well formed before you start constructing surfaces and solids based off of them.
> In General as a workflow, do I fillet things as I go or, is it done as a final edge polish pass?
You can do it as you go if the areas being filleted are isolated from other fillets. When they are going to be running into each other then they usually should be done all at the same time.
Show messages: All  1-8  9
