Boolean difference solids generates thin walls?
All  1-2  3-8
9592.3
OK. Here is the file.
9592.4 In reply to 9592.3
Your object seems perfect! :)
So seems your Print programs don't know how to fill the internal part...have you try to scale your original?
EDITED: 23 Nov 2019 by PILOU
9592.5
That is interesting. I used the latest Anycubic photon slicer. I have since redone the piece in meshmixer using make solid and I think it behaves better now. Good to know it is not a MOI issue.
9592.6 In reply to 9592.1
Hi MA, I think you might run into some problems with slicers considering your object to have areas of self-intersection because the cylinder and inner wall basically touch or graze very close to each other in these areas here:
It would probably be good to have a little bit of spacing here:
Basically when the slicer goes to slice your STL file in order to form proper regions the slices need to make well formed intersections with a plane which means the intersections result in closed loops. When 2 different surface areas are very closely pinched together it can make it hard to get a clean intersection result at those areas and that can potentially mess things up.
So for 3D printing, try to avoid making really thin sharp needle type things like this:
The eyes' master! ;)
But the meshmixer shows also default on around the external skin ?
9592.8 In reply to 9592.7
Hi Pilou, probably the self-intersecting or nearly-self-intersecting areas will also confuse meshmixer as well.
Show messages: All  1-2  3-8
