obj export for sculpting
All  1-3  4-7
9584.4 In reply to 9584.1
Hi Tom, try using the "Divide larger than" setting when exporting out from MoI, see here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
9584.5 In reply to 9584.1
Hi Tom, when you say "sculpting purposes" I was thinking you were talking about displacement brush sculpting like as in ZBrush or 3D-Coat. That's when having a finely diced up mesh as in the link above can be helpful.
But do you instead mean that you want to do sub-d smoothed subdivision and control point manipulation in Cinema4D ? If so then that's a much different thing. For that you'll need to do a process called "retopology" to construct a sub-d smoothing friendly mesh from your original one. The one that MoI exports will not be suitable for use as a sub-d smoothing cage.
Do an internet search on "retopology" to get more information on the conversion process, here's one result:
https://cgcookie.com/course/introduction-to-retopology
But you may be better off just constructing the sub-d friendly mesh in C4D from the beginning though instead of trying to use MoI for that type of result.
9584.6 In reply to 9584.5
I am indded looking for displacement brush sculpting - in Cinema.
So Pilou was right, there are settings to fill up an area with triangles and quads.
What are the best methods to achieve the sharpest edges possible while trying
to keep RAM consuming features low ?
9584.7 In reply to 9584.6
Hi Tom,
Try using the "Divide larger than" setting, there is an example here:
You put in a distance value there and any polygons larger than that distance will get subdivided.
The specific value to use depends on the scale of your object and how dense you want it.
For example if you have an object that's 1000 units across, do not put in a "Divide larger than" value that's very small like 0.001 because that's asking to make a tremendously dense result.
For a regular sized object try starting with "Divide larger than" of 1.0, then try going down in steps.
Show messages: All  1-3  4-7
