Sweep using rails with corners
All  1  2-5
Make a filet on the rectangle before the sweep :)
957.3 In reply to 957.1
Hi Steve, this is a limitation currently in MoI's sweeper.
It takes extra work to handle mitering the corners and I haven't had time to set that up for version 1 of MoI.
It is something that I intend to add though.
There are various work-arounds, for example use 2 rails with corners for a 2-rail sweep instead, but the easiest for now is to use Rhino for that kind of sweep.
A simple rail revolve makes the trick :)
EDITED: 25 Sep 2007 by PILOU
957.5
The rail revolve looks OK except that it scales the profile depending on how far the edge is from the centre of revolution.
Show messages: All  1  2-5
