Extend / extrude "tangentially"
 1-6  7-22
9567.7 In reply to 9567.6
The ending edge of the current surface is not a circle because the surface is cut at an angle. Note that turning on control points you can see the underlying surface is like this:
Untrim the surface and then you can get a planar end circle edge that can be extruded.
9567.8 In reply to 9567.6
Of course it is a possibility, but how to get the right XYZ angle ?
9567.9 In reply to 9567.8
Tangent Helper as above ?
9567.10 In reply to 9567.5
>>Hi Tom, yes the Edit > Extend command can be used to extend a curve.<<
Great ! downloading the file and having a look !
9567.11 In reply to 9567.9
Yes thats cool. Will have a look at both of your kind tips !
9567.12 In reply to 9567.11
An extrude by a single tangent direction won't be quite right because the tangents are slightly different on each side. That's because the surface is cut at an angle as described above. They're only a little bit different though since the surface is only very slightly bent so it will be hard to tell visually.
But if you want a precise result then doing the untrim will recover a planar ending edge that can be extruded to get an accurate tangent extension.
9567.13
Michael, I am using the extend command all the time if I have another curve to extend it.
I thought that you meant that is also possible extend a curve into "empty space",
but this does not work, doesnt it ?
9567.14 In reply to 9567.13
Hi Pilou, here's an example with a tube that is more tightly bent and cut at a greater angle to show you how there isn't one single tangent direction in a case like this:
When you untrim it then you'll get a natural tube end which does have a single tangent direction.
9567.15 In reply to 9567.13
Hi Tom,
Empty space does not have to stay empty, you can draw in a temporary boundary object, extend to that and then delete the boundary object.
9567.16 In reply to 9567.13
Hi Tom, also re: Extend command - the boundary object does not have to be a curve it can also be something a sphere or a plane.
9567.17 In reply to 9567.14
When you say "Untrim" in this case of this tube what is untrimed ? Curve? Section ? Surface ? ...
Untrim is "Separate" ?
EDITED: 7 Nov 2019 by PILOU
9567.18 In reply to 9567.17
Hi Pilou, it's this surface here that would be untrimmed, the same one that wants to get extended:
To untrim it, use Edit > Separate on it first to make it an independent single surface not joined to anything else. Then select all its edges and do a Delete. The trimming boundary will be removed and the full underlying surface will be recovered.
The other end that will not be extended needs to be retrimmed.
9567.19 In reply to 9567.18
OK!
And this
Extrude --> Boundary Sphere ?
9567.20 In reply to 9567.17
> Boundary Extrude --> Sphere ?
I'm sorry I don't understand this question. The mention of a sphere above was about the Edit > Extend command, not the Extrude command.
9567.21 In reply to 9567.20
Sorry I have read Extrude so now i better understand! :)
9567.22
Always amazed by your support - very very helpful tips !
Show messages:  1-6  7-22
