Extend / extrude "tangentially"
 1-16  17-22
9567.17 In reply to 9567.14
When you say "Untrim" in this case of this tube what is untrimed ? Curve? Section ? Surface ? ...
Untrim is "Separate" ?
EDITED: 7 Nov 2019 by PILOU
9567.18 In reply to 9567.17
Hi Pilou, it's this surface here that would be untrimmed, the same one that wants to get extended:
To untrim it, use Edit > Separate on it first to make it an independent single surface not joined to anything else. Then select all its edges and do a Delete. The trimming boundary will be removed and the full underlying surface will be recovered.
The other end that will not be extended needs to be retrimmed.
9567.19 In reply to 9567.18
OK!
And this
Extrude --> Boundary Sphere ?
9567.20 In reply to 9567.17
> Boundary Extrude --> Sphere ?
I'm sorry I don't understand this question. The mention of a sphere above was about the Edit > Extend command, not the Extrude command.
9567.21 In reply to 9567.20
Sorry I have read Extrude so now i better understand! :)
9567.22
Empty space does not have to stay empty
Always amazed by your support - very very helpful tips !
Show messages:  1-16  17-22
