AI export to Photoshop
All  1  2-7
9557.2 In reply to 9557.1
Hi Tom, try using PDF format instead of AI, like this:
script:moi.geometryDatabase.copyToClipboardPDF();
When you export out from MoI set Scale = "Preserve units" and uncheck "Center on page". Then in Photoshop under Edit > Preferences > General uncheck "Resize Image During Paste/Place".
Over here that seems to do it, but it only seems to work for PDF format in the clipboard, not AI format. That seems to be a Photoshop problem, I get the same behavior with putting AI format in the clipboard from Adobe Illustrator as well.
9557.3 In reply to 9557.2
Does not work for me - could it be because I
am using an older version of Photoshop ?
9557.4 In reply to 9557.3
Hi Tom,
I was testing it here with an old version myself (CS2)...
I guess I'll need more details about exactly how you're trying to do it, are you possibly exporting a 3D perspective view projection instead of an ortho view?
9557.5 In reply to 9557.4
Using CS4 and top view export.
9557.6 In reply to 9557.5
Hi Tom, so it wasn't working over here it just looked like it with the object I happened to test with.
It doesn't seem like Photoshop CS4 or earlier is able to do that, I found a mention here that starting with CS5 there is a "Paste in place" function:
http://blogs.adobe.com/jnack/2010/04/paste_in_place_comes_to_photoshop_illustrator_cs5.html
9557.7 In reply to 9557.6
Ok good to know !
Show messages: All  1  2-7
