Make a hole smaller or bigger
All  1-6  7-15
Here the French version! ;)
http://moiscript.weebly.com/r2d3.html
9554.8 In reply to 9554.6
>Can you give a name to the "future new hole(s)" inside your code for an easy selection for make the last Diff ?
Yes! :-)
EDITED: 2 Nov 2019 by R2D3
9554.9 In reply to 9554.8
Not yet tested but sure that will be excellent!
Merci!
9554.10 In reply to 9554.9
Works fine
Many many Thanks to r2d3 and PILOU
EDITED: 2 Nov 2019 by CHRI
Tested the new "Name": works like a charm!
Only little disturb about the all command: undo is not completly supported!
But it's yet a wonderful task!
PS You can "Copy" the "Hole Tool" anywhere you want before the last Diff ;)
Here the Hexagon on the Right is the final result of a move &/or scale of an original
You can easily Select by its name "Hole Tool" in the Browser Object by a Right Click
Now it is copyied 2 times on the Left!
Then the Last Boolean Diff can be made! (not supported by the command but it's not a big deal :)
And you can copy any separate hole (at the end they will have the same name so easy to select them!
So a new French version! ;)
EDITED: 2 Nov 2019 by PILOU
@r2d3
Seems your wonderful prog don't works for wavy volumes ?
Have you some tricks or future ideas for that ?
Now it's the big manually DIY work! :)
9554.13 In reply to 9554.12
This script relays on MOIs "SelfHealing" capabilities. Holes on curved or splited faces can't be selfhealed.
Need for Moments of Inspiration...
Have fun! ;-)
Ralf:)
looking for moments of inspiration...
9554.14 In reply to 9554.11
YES thats right...
@Michael Gibson > Do you have an idea ???
Ralf:)
9554.15 In reply to 9554.14
Hi Ralf,
I think that having an object that's created and then also deleted within the same command can mess up the automatic undo tracking.
Show messages: All  1-6  7-15
