Make a hole smaller or bigger
All  1-9  10-15
9554.10 In reply to 9554.9
Works fine
Many many Thanks to r2d3 and PILOU
EDITED: 2 Nov 2019 by CHRI
Tested the new "Name": works like a charm!
Only little disturb about the all command: undo is not completly supported!
But it's yet a wonderful task!
PS You can "Copy" the "Hole Tool" anywhere you want before the last Diff ;)
Here the Hexagon on the Right is the final result of a move &/or scale of an original
You can easily Select by its name "Hole Tool" in the Browser Object by a Right Click
Now it is copyied 2 times on the Left!
Then the Last Boolean Diff can be made! (not supported by the command but it's not a big deal :)
And you can copy any separate hole (at the end they will have the same name so easy to select them!
So a new French version! ;)
http://moiscript.weebly.com/r2d3.html
EDITED: 2 Nov 2019 by PILOU
@r2d3
Seems your wonderful prog don't works for wavy volumes ?
Have you some tricks or future ideas for that ?
Now it's the big manually DIY work! :)
9554.13 In reply to 9554.12
This script relays on MOIs "SelfHealing" capabilities. Holes on curved or splited faces can't be selfhealed.
Need for Moments of Inspiration...
Have fun! ;-)
Ralf:)
looking for moments of inspiration...
9554.14 In reply to 9554.11
YES thats right...
@Michael Gibson > Do you have an idea ???
Ralf:)
9554.15 In reply to 9554.14
Hi Ralf,
I think that having an object that's created and then also deleted within the same command can mess up the automatic undo tracking.
Show messages: All  1-9  10-15
