Normal thickness ?
All  1-6  7-10
9553.7 In reply to 9553.6
Thanks all is more clear now and explain why some things works or not!
That was not evident! :)
Hoppefuly there always another way to go (like above the "copy move") depending of the result wished...
In the same order of idea it's not obvious that the function "Extrude" can't extrude this ribbon face...
just some parts if they are trimmed...
EDITED: 1 Nov 2019 by PILOU
9553.8 In reply to 9553.7
Well extrusion is something that actually happens to curves. When you extrude a surface what actually happens is all the edge curves of the surface are extruded and then the surface is copied to the end to make a cap.
Extrusion of curves works by translating the curve in a fixed direction.
What direction are you expecting to use for those curves such that they don't cross over and interfere with themselves making a "self-intersecting" result?
9553.9 In reply to 9553.8
There is a Joint Push Pull inside SketchUp who Extrude the curvated ribbon face above ;)
In Moi that will be the Shell...
As we can extrude these flat vertical faces ribbon (even they auto intersect during the extrusion) it's tempting to make the same with the curvating above! :)
9553.10 In reply to 9553.9
> There is a Joint Push Pull inside SketchUp who Extrude the curvated ribbon face above ;) <...>
SketchUp doesn't have actual curved surfaces, only flat polygons.
If you divide the curved surface into flat pieces then an extrusion for each flat piece will be better defined.
Since MoI works on true curved spline surfaces there are different kinds of issues with possible self intersections.
Show messages: All  1-6  7-10
