MoI node editor for beginner
 1-6  7-26  27-46  47-54
9547.47 In reply to 9547.46
Thank you, pior, for the explanations. (And WM as well.)
My past attempts to use MS Word for anything have been very unfruitful, and very awkward.
9547.48 In reply to 9547.1
i see the exact same thing. the 0.97 install seems to be missing something. did i miss a step?
9547.49 In reply to 9547.48
Hi mike,
Can you maybe describe a bit more about what problem you're seeing?
Is it that the CustomUI "NodeEdit" button is showing a blank window?
9547.50
yes, exactly
it is that the CustomUI "NodeEdit" button is showing a blank window
i installed this version of the nodeeditor
https://moiscript.weebly.com/install-elephant.html
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodeeditor_1.zip
@'y'@ 0.97
9547.51 In reply to 9547.50
Hi mike,
Do you possibly have the .zip file name in the path?
Like nodeeditor_1\nodeeditor\index.htm ?
If so then it won't find it because it's looking for
moi://appdata/nodeeditor/index.html
and you've instead got
moi://appdata/nodeeditor_1/nodeeditor/index.html
If that isn't it please show a screenshot of where you have it installed to.
9547.52
sure, thanks
here is my screenshot
Size: 75.2 KB, Downloaded: 126 times, Dimensions: 1872x965px
9547.53 In reply to 9547.52
Hi mike, that sure looks correct.
I think maybe that nodeeditor might be an old version from moi v3 that is expecting to be put in the "c:\Program Files" install folder instead of in appdata.
Try with this one instead:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
9547.54
great thanks,
that works -- awesome :)
Show messages:  1-6  7-26  27-46  47-54
