MoI node editor for beginner
 1-20  21-40  41-54
9547.41 In reply to 9547.40
Hello !
Well first of all thank you for all the efforts that obviously went into it, as it looks like it covers pretty much everything.
Depending on how useful the Node Editor turns out to be for my own uses I might end up making a simplified, linear PDF version out of these help pages for easy reading. I'll let you know if that happens.
Regarding maintenance : well, even the most appropriate solutions for the authoring of such pages (like the very popular ReadTheDocs Python generator) can quickly become a pain as soon as the technical aspects (building the pages) gets in the way. So yeah as said I feel like the most streamlined solution is just a good old PDF with a bunch of pictures generated from a text document - just like the UE Compendiums really :)
Anyways, time to learn some node stuff now.
9547.42 In reply to 9547.41
Here's a PDF combining all the help pages I've found, organized linearly. This is very raw as page breaks happen in unexpected places but it does the job of putting everything in one place as opposed to having to click many links. I quickly removed as much fluff as possible (like the repeating groups of links), hopefully without accidentally removing something important. Let me know if I forgot a page or some important ressource.
https://drive.google.com/file/d/1oRpUDw3nsM56R9iha9_vMDMccJCdDtLP/view?usp=sharing
And a source .ODG if anyone is brave enough to get in there and sort the layout :D
https://drive.google.com/file/d/1jbgjPUY9SLsKmEP4oQsRgLboPinfmPCk/view?usp=sharing
It would be interesting to also add some of the images and node networks by @Nodeology, so if anyone as them downloaded already let me know and I'll add them. Or, feel free to add them yourself and re-host.
Best,
P.O.
EDITED: 7 Dec 2022 by PIOR_O
9547.43 In reply to 9547.42
Hi pior,
Thank you for your work.
For 3840 X 2160 display resolution, the Font is way too small for myself. Zooming in does not help much.
Is there an easier Font to read? I dislike the Font, but do not know which font would be better.
Never used .odg file format. Loaded Libre Office, which promptly crashed on the .odg file...
I've never used Libre Office before...
Is there a better XML editor?
Is there an XSLT stylesheet for the XML document?
9547.44 In reply to 9547.42
@Prior
Cool work with my base Elephant Node Editor site! ;)
9547.45 In reply to 9547.43
Hi Brian.
Size: 125.2 KB, Downloaded: 85 times, Dimensions: 1257x696px
9547.46
Brian, WM : FWIW it was generated by simply performing a "print to PDF" on all the individual web pages, then stitched together using GiosPDFSM, and then basic edits were done in LibreOffice. All that to say that I didn't do anything about font size and left it all as it was, since styling is less important than content :)
As for sources of inspiration for visual styling, the UE4 Blueprint Compendiums mentionned earlier would probably be a good starting point ; as well as any PDF export from any documentation site made with ReadTheDocs. Here's an example : https://docs.readthedocs.io/_/downloads/en/latest/pdf/
(I personally strongly dislike ReadTheDocs when it comes to *writing* documention, it's just painful and annoying. But the output itself is really quite clean visually.)
As for opening the .ODG : on my end I am using LibreOffice 7.2.7.2.
FP : no problemo, I needed to do it anyways in order to be able to parse through it all without losing my sanity :D Great work again on all the examples, it looks like everything is well covered really.
9547.47 In reply to 9547.46
Thank you, pior, for the explanations. (And WM as well.)
My past attempts to use MS Word for anything have been very unfruitful, and very awkward.
9547.48 In reply to 9547.1
i see the exact same thing. the 0.97 install seems to be missing something. did i miss a step?
9547.49 In reply to 9547.48
Hi mike,
Can you maybe describe a bit more about what problem you're seeing?
Is it that the CustomUI "NodeEdit" button is showing a blank window?
9547.50
yes, exactly
it is that the CustomUI "NodeEdit" button is showing a blank window
i installed this version of the nodeeditor
https://moiscript.weebly.com/install-elephant.html
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodeeditor_1.zip
@'y'@ 0.97
9547.51 In reply to 9547.50
Hi mike,
Do you possibly have the .zip file name in the path?
Like nodeeditor_1\nodeeditor\index.htm ?
If so then it won't find it because it's looking for
moi://appdata/nodeeditor/index.html
and you've instead got
moi://appdata/nodeeditor_1/nodeeditor/index.html
If that isn't it please show a screenshot of where you have it installed to.
9547.52
sure, thanks
here is my screenshot
Size: 75.2 KB, Downloaded: 126 times, Dimensions: 1872x965px
9547.53 In reply to 9547.52
Hi mike, that sure looks correct.
I think maybe that nodeeditor might be an old version from moi v3 that is expecting to be put in the "c:\Program Files" install folder instead of in appdata.
Try with this one instead:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
9547.54
great thanks,
that works -- awesome :)
Show messages:  1-20  21-40  41-54
