Hide + show
All  1-2  3-5
9543.3 In reply to 9543.2
Hi Michael , I use isolate all the time, very helpful command.
So what I am looking for could be described as a negative isolate fuctionality.
If I hide one object with the default "hide" and try to mae it visible again, it
diplays ALL hidden objects which is not helpful when I want to keep my
scene as before just adding teh previously hidden object. It get specially
confusing when there is a huge number of hidden objects which suddenly
get displayed at once.
9543.4 In reply to 9543.3
Hi Tom, sorry no there isn't anything set up for that. But if you want the same as "negative isolate", I'd think you could get that by inverting the selection and then using regular isolate... ?
It is also possible to show only some of the hidden objects and not all of them by using the "Show subset" function which you can access by a Ctrl+click on the Edit > Hide button.
"Show subset" will temporarily show all hidden objects but then will pause and let you select the ones of interest. When you're done selecting the ones that you did not select will go back to being hidden.
If you need more fine tuned control over hide/show instead of everything the other main way to accomplish that is to assign a name to your object so you can use the scene browser to hide and show it rather than the Edit > Hide button only.
9543.5 In reply to 9543.4
Hi Michael, thats what I thought, just invert the selection and then isolate.
I willgo through the other hide-scripts to see how they work.
Thanks for helping ! TOM
Show messages: All  1-2  3-5
