Torus Coil
All  1  2-8
9540.2 In reply to 9540.1
Hi Don, to use the Transform > Deform > Flow command you need 3 objects - your object that you want to deform, then the base backbone curve (usually a line) and then a target backbone curve.
It looks like you only have 2 curves there, the problem is you're missing the base backbone curve. That would be a line running down the middle of your helix.
Once you have that, then the process is: select curve you want to deform (your helix), then select the first backbone curve (the line down the middle of the helix that you are currently missing) then the target curve (the circle).
9540.3 In reply to 9540.2
Fantastic! Thanks Michael. Here is a screen capture before selecting done with stretch checked.
_________________________
Don Cheke
Visit: Textual Creations
Size: 156.6 KB, Downloaded: 79 times, Dimensions: 710x830px
9540.4
Well, that was super easy in MoI! Thanks for your assistance Michael.
Don Cheke
Size: 78.3 KB, Downloaded: 52 times, Dimensions: 844x577px
9540.5 In reply to 9540.4
You're welcome Don!
Message 9540.6 deleted 22 Oct 2019 by DON_CHEKE
9540.7 In reply to 9540.5
Don't know if you are interested but here is the MoI model exported out to Alibre and rendered in KeyShot
Don Cheke
Visit: Textual Creations My Instagram: don.b.cheke
Size: 684.3 KB, Downloaded: 86 times, Dimensions: 1200x672px
9540.8 In reply to 9540.7
It is a beauty!
There is also the ToroidalHelix script.
Show messages: All  1  2-8
