Error with unwrap curve
All  1-5  6-8
9539.6 In reply to 9539.4
Ok but as the same function has the htm companion in the V3 I was perplex! :)
9539.7 In reply to 9539.6
I see - so for this command if you preselect the curve then when you trigger the command it will find that curve and be able to immediately do its action. It does not need to show any UI in that case so the missing UI doesn't matter.
If it can't find the curve then it will prompt you to select curves. That second one with the selection prompt won't work properly without the .htm file.
9539.8
Apologies for the delay in replying, i think I got caught up in having copied the script in a recently expired beta version and then didn't copy it in the newly downloaded version.
Many thanks all - support on this forum is absolutely top notch and always has been :)
Gunter
Show messages: All  1-5  6-8
