What is this UI ?
All  1-7  8-13
9535.8 In reply to 9535.5
For installation it goes like this - unzip C:\scripts\CustomUI.2.0.beta2.zip and you have 3 folders: "customui", "objects", and "startup".
These need to be copied over into the MoI appdata folder, which you can go to by typing in %appdata%\moi in at the windows start menu.
So you should have %appdata%\moi\customui , %appdata%\moi\objects, and %appdata%\moi\startup . The "startup" folder will be there already, copy the contents of the customui startup folder into the existing one. The other 2 ones will be new folders that you will add.
Ok that works : I have now 40 icons on the Bar tool! :)
I must make a little cleaner !
9535.10 In reply to 9535.9
40 icons confirmed:-)
i write "-22 CPlane.jsk for "clean" and don't erase definitively it for the moment
because only -22 CPlane.js is not sufficient! : seems working :)
With all that I have losted the Wayne's "Custom Scripts" I have the icon but nothing inside (icons)! :)
Maybe the scripts of Wayne are incompatible ?
What is LogScroll.js ?
EDITED: 18 Oct 2019 by PILOU
9535.12 In reply to 9535.11
It looks like a dialog that will show the debug log and will refresh itself so it can be kept open.
Ok I re follow the Wayne Install ...so now all is ok! So all compatible!
I have the 3 Icons Buttons Scripts (2 gears) + Windows with all text functions, the Lighting (bulb) and the Custom Scripts (2 gears) with colored icons...
so sufficient for me! :)
Show messages: All  1-7  8-13
