 1-2  …  163-182  183-202  203-222  223-233
9526.203 In reply to 9526.20
great features, the Area and Volume Details help a lot!
A nice feature would be to be able to define different units for them. Engineering designs are in mm (in Europe) but we purchase materials e.g. in liters (dm3) or m2 or calculate the weight based on roh in cm3 or need volumes in m3 as it's a standard unit for calculations. Of course we are all able do the math but it would be a nice-to-have.
S.
9526.204 In reply to 9526.203
Hi skipper I'm glad the area and volume calculations will be helpful!
I do want to enable switching those to different units like you're asking but it probably won't get done in the v4 time frame.
Thanks, - Michael
9526.205 In reply to 9526.204
Could object scale place a cap on the number of polys I can get during .obj export? I have a solid that seems to be unaffected by anything smaller than 3 decimals (in divide larger than field of the exporter). I usually can ramp up the resolution, but now it caps at 400k polys. :O
9526.206 In reply to 9526.205
Hi nameless, yes if the polygon edge length goes much under the regular modeling tolerance level it will start to consider points to be too close together and not refine them further. The standard fixed modeling tolerance level is 0.001 units. It's not so good to make objects that are going to have features that are around or smaller than that size.
In general it's best to avoid using a unit system that makes you have numeric values that are smaller than around 0.05 units or so in size like you are doing here. Instead of using meters with some model features around 0.0001 in length like you have it I would recommend having units = centimeters for this object.
I am trying to convert things that use a fixed tolerance to instead use a fraction of the object's bounding box size so that it can adapt to objects with unusually large or small object sizes but I think it is too late in the beta release cycle to attempt to do that for meshing right now.
There are other things that will not accommodate really tiny objects very well like .obj format for example writes out coordinates in a text file and so you would need to bump up the number of decimal places used for the text representation of coordinates with such small object sizes.
There also may be just a general loss of precision for numeric calculations when objects have very large or very small numeric values.
One thing to note is that whether an object is considered unusually large or small is about how many decimal places are used in its coordinate values, like if you have values of 10000000.0 or 0.000000001 , regardless of what the current unit system is set to.
9526.207 In reply to 9526.206
I see! Thank you for explaining it in such detailed manner. Is the weird topology that I am attaching during export of a simple cube, symptom of small scale?
In addition, I just realized that I can use the scale factor option on the Import/Export preferences and equalize things that way instead. That should have been my first move to begin with...
Size: 984.9 KB, Downloaded: 130 times, Dimensions: 1729x1101px
9526.208 In reply to 9526.207
Hi nameless,
Yes, I think so.
9526.209
Probably been asked before just cant find it in the string of posts - is the dimensions tool going to have a global preference for document used in terms of font size and general dimensions prefs. Something you can setup for the document your working on and it keeps those preferences as you work on new dimensions for that doc. You could be working on a large or small scale documents independently.
9526.210 In reply to 9526.209
Hi Alex,
Yup, that's pretty much the next thing that I'm working on. Once it is in place I'll release a new beta.
9526.211
thanks for the update - looking forward to next realease.
regards
Alex.
9526.212
Just did a fresh install of WIN10 latest build on my workstation and just installed MOI4 when I go to export STL or OBJ the shape polycount comes up but the MESHING OPTIONS window does not and just hangs there. All other export modules work fine. Is there any other software which this could be reliant on and needs to be installed.
thanks
Alex.
9526.213 In reply to 9526.212
Hi Alex, no there isn't any other software that should need to be installed. Is your screen maybe a different resolution and it's off screen?
What happens if you edit moi.ini and delete the "DialogLocataion" line inside the [Mesh Export] section? :
[Mesh Export]
DialogLocation=946,375
9526.214
thanks it had negative values - I deleted and now AOK.
All the best for 2020.
regards
Alex.
9526.215 In reply to 9526.214
Hi Alex, that's great I'm glad you're up and running again! I will see if I can ignore coordinates like that. I think that could happen if the moi.ini file was created on a system with a different multi-monitor layout than your new system.
9526.216 In reply to 9526.215
Hello,
When will the new version of MOI3D be released?
9526.217 In reply to 9526.216
Hi hunter, there should be another beta out within a few days I hope. There will still be one more beta after that before the final one. There is still some stuff to finish up with dimensions.
9526.218 In reply to 9526.215
Hi Michael, On my main workstation I have 1 34inch widescreen as my main screen - replaced 2 screens but I use a wacom touch screen which is positioned below the widescreen so a little different to your horizontal multi screen setup. I would say as the widescreens come down in price multiscreens setups will drop off not having a join in the middle is so much better.
thanks again.
9526.219 In reply to 9526.218
No way I would replace my multiple screens with a wide screen. 2 screens give me 2 distinct areas that I can maximize windows to. 4 if using Windows+Arrow-Left and Windows+Arrow-Right.
9526.220
I apologise if this has already been discussed. I use MoI for exporting CAD via LWO to Modo. It's great! But I've noticed in the V4 Beta that I'm getting a lot more problems with flipped polys in the export mesh than I do in V3.
Ideally I would just use double-sided materials in Modo/VRay but then there's problems using rounded edge shaders because of the surface normals, so I have to go and flip any problem polys by hand (which can take a long time!)
Cheers,
Will
9526.221 In reply to 9526.220
Hi Will, do you have an example model that you can post here or e-mail to me at moi@moi3d.com that behaves differently in the mesh export between v3 and v4?
Thanks, - Michael
9526.222 In reply to 9526.221
Thanks Michael, I've sent you an email with a test file.
Cheers,
Will
Show messages:  1-2  …  143-162  163-182  183-202  203-222  223-233
