V4 beta Oct-10-2019 available now
 1-17  …  158-177  178-197  198-217  218-233
9526.198 In reply to 9526.197
Hey Michael! :) I edited the original message with the .gif and added a 3dm. Let me know if you need anything else.
Keep in mind that I fiddled with MoI's scale as you know and it could be related to that.
9526.199 In reply to 9526.198
Hi nameless, so there's a thing built in to Sweep called "autoplace mode" which determines whether the sweep should start directly from the curve as given, or whether the profile should be moved and rotated to the start of the path curve and then swept starting from there.
Autoplace mode is implicitly turned on or off depending on whether the profile curve is inside the bounding box around the rail or outside of the rail's bounding box.
So your weird result is happening because autoplace mode is off somehow during the history update. That seems like a bug so I'll investigate why it is off then. Other kinds of edits like move/rotate/scale of the whole profile curve seem to be working ok, it's during a control point edit that it looks like there is an autoplace bug.
9526.200 In reply to 9526.199
I see! That solves the mystery :) Thank you for looking into it Michael.
And in danger of a mild thread highjack- I have been trying to find a way to map something like this-> script:moi.ui.getActiveViewport().Zoom( 0.9 ); on my mouse wheel in an attempt to mitigate the jump caused by the small scale issue we were talking about. Is by any chance any .ini setting describing what the mouse wheel scroll does inside MoI? Or a way to smuggle a Ctrl press along with it :))
9526.201 In reply to 9526.200
Hi nameless, re: mouse wheel - currently if you hold down Ctrl and use the mouse wheel it will take a smaller step size than the regular one, is that what you mean? There isn't currently any way to adjust the speed in moi.ini though.
Also the history bug looks like a regression in v4 - v3 seems to behave properly. So that might also help me to track down the bug.
9526.202 In reply to 9526.201
Wow, I fished a V4 specific bug?! :)
I temporarily solved the other issue. I used a free program called XMouseButtonControl (which I recommend!) that lets you customize all aspects of mouse behavior and has program specific profiles. So when I load MoI, my scroll has the Ctrl modifier attached. Seems like an awesome utility. Now I can navigate my tiny MoI Viewport without teleporting!
9526.203 In reply to 9526.20
great features, the Area and Volume Details help a lot!
A nice feature would be to be able to define different units for them. Engineering designs are in mm (in Europe) but we purchase materials e.g. in liters (dm3) or m2 or calculate the weight based on roh in cm3 or need volumes in m3 as it's a standard unit for calculations. Of course we are all able do the math but it would be a nice-to-have.
S.
9526.204 In reply to 9526.203
Hi skipper I'm glad the area and volume calculations will be helpful!
I do want to enable switching those to different units like you're asking but it probably won't get done in the v4 time frame.
Thanks, - Michael
9526.205 In reply to 9526.204
Could object scale place a cap on the number of polys I can get during .obj export? I have a solid that seems to be unaffected by anything smaller than 3 decimals (in divide larger than field of the exporter). I usually can ramp up the resolution, but now it caps at 400k polys. :O
9526.206 In reply to 9526.205
Hi nameless, yes if the polygon edge length goes much under the regular modeling tolerance level it will start to consider points to be too close together and not refine them further. The standard fixed modeling tolerance level is 0.001 units. It's not so good to make objects that are going to have features that are around or smaller than that size.
In general it's best to avoid using a unit system that makes you have numeric values that are smaller than around 0.05 units or so in size like you are doing here. Instead of using meters with some model features around 0.0001 in length like you have it I would recommend having units = centimeters for this object.
I am trying to convert things that use a fixed tolerance to instead use a fraction of the object's bounding box size so that it can adapt to objects with unusually large or small object sizes but I think it is too late in the beta release cycle to attempt to do that for meshing right now.
There are other things that will not accommodate really tiny objects very well like .obj format for example writes out coordinates in a text file and so you would need to bump up the number of decimal places used for the text representation of coordinates with such small object sizes.
There also may be just a general loss of precision for numeric calculations when objects have very large or very small numeric values.
One thing to note is that whether an object is considered unusually large or small is about how many decimal places are used in its coordinate values, like if you have values of 10000000.0 or 0.000000001 , regardless of what the current unit system is set to.
9526.207 In reply to 9526.206
I see! Thank you for explaining it in such detailed manner. Is the weird topology that I am attaching during export of a simple cube, symptom of small scale?
In addition, I just realized that I can use the scale factor option on the Import/Export preferences and equalize things that way instead. That should have been my first move to begin with...
Size: 984.9 KB, Downloaded: 130 times, Dimensions: 1729x1101px
9526.208 In reply to 9526.207
Hi nameless,
Yes, I think so.
9526.209
Probably been asked before just cant find it in the string of posts - is the dimensions tool going to have a global preference for document used in terms of font size and general dimensions prefs. Something you can setup for the document your working on and it keeps those preferences as you work on new dimensions for that doc. You could be working on a large or small scale documents independently.
9526.210 In reply to 9526.209
Hi Alex,
Yup, that's pretty much the next thing that I'm working on. Once it is in place I'll release a new beta.
9526.211
thanks for the update - looking forward to next realease.
regards
Alex.
9526.212
Just did a fresh install of WIN10 latest build on my workstation and just installed MOI4 when I go to export STL or OBJ the shape polycount comes up but the MESHING OPTIONS window does not and just hangs there. All other export modules work fine. Is there any other software which this could be reliant on and needs to be installed.
thanks
Alex.
9526.213 In reply to 9526.212
Hi Alex, no there isn't any other software that should need to be installed. Is your screen maybe a different resolution and it's off screen?
What happens if you edit moi.ini and delete the "DialogLocataion" line inside the [Mesh Export] section? :
[Mesh Export]
DialogLocation=946,375
9526.214
thanks it had negative values - I deleted and now AOK.
All the best for 2020.
regards
Alex.
9526.215 In reply to 9526.214
Hi Alex, that's great I'm glad you're up and running again! I will see if I can ignore coordinates like that. I think that could happen if the moi.ini file was created on a system with a different multi-monitor layout than your new system.
9526.216 In reply to 9526.215
Hello,
When will the new version of MOI3D be released?
9526.217 In reply to 9526.216
Hi hunter, there should be another beta out within a few days I hope. There will still be one more beta after that before the final one. There is still some stuff to finish up with dimensions.
Show messages:  1-17  …  138-157  158-177  178-197  198-217  218-233
