V4 beta Oct-10-2019 available now
 1-16  …  137-156  157-176  177-196  197-216  217-233
9526.177 In reply to 9526.176
I think I tried most options to force a re-draw (like zooming, panning, drawing in the dark, minimizing Moi3d-window, maximizing again, etc.). Screen kept black. Restarting MOI of course solved the issue ;o)
Greetz,
Joerg
9526.178 In reply to 9526.177
Hi, i had the same problem with a quadro card (m2000m). I solved it with another driver. Maybe it's some kind of driver issue ?
Moujiik
9526.179 In reply to 9526.177
Hi Joerg, yes it is probably video driver related. If you keep running into it I'd recommend checking on the NVidia web site to see if there is an updated driver available.
The reason you may have not seen this with V3 is that MoI v3 used the Direct3D9 system for connecting to the video card while MoI v4 uses Direct3D11 instead.
9526.180
Thank you for the release, Michael.
How can I avoid dimensions and texts to scale up and down when I zoom in and out the window?
Thank you,
Massimo.
9526.181 In reply to 9526.180
Hi Massimo,
Currently the text is designed to be an annotation that stays the same size on screen no matter what the current zoom level.
There isn't a way to change that right now but I do plan on making an option for model-size dependent text that scales like model geometry.
I will also probably do some additional refinement of the current scale-independent method to allow them to shrink if you are zoomed out a lot. I'm not sure if this refinement will make it in to v4 or not though.
9526.182
Probably been asked before but with the DIMS module will this have a global text size adjustable to the open document. So if your working on large items the dims are relevant to the scale working in that document.
Also when working with other file formats and opening or importing into a new doc is it possible for the MOI to default file name that is came from this action is standard in RHINO and Solidworks to name a few.
EDITED: 26 Jan 2020 by ALEXPOLO
9526.183 In reply to 9526.182
Hi Alex,
The current initial method is that the text is scale independent and stays the same size on screen no matter what the size of your model. So the current dims already solve that problem, they don't need any adjustment depending on whether you are working with large sized models or small sized models.
That's basically why the initial focus is on having scale independent text that is always the same screen size, then you don't have to worry about these kinds of scale issues that you are describing here.
I do plan on having a setting for model scale dependent text as well, I'm not quite sure yet on the specifics of how that will work.
MoI does not do this because .3dm format is the only format that can contain everything that you can create in MoI including stuff like background images for example. So the current file name is only set if you open .3dm format, that way there isn't any chance for there to be data loss if you have created things that do not save to .DXF format for example.
There is a setting in moi.ini that you can set to modify some of this behavior, that's under:
[Settings]
SetNameWhenOpeningAllFileTypes=y
When set, the current file name is set for all file opens not just .3dm files.
9526.184
Thanks for the info thats great and the SETNAME option in the ini is another hidden gem. Moi opens so fast I use it as my default file viewer for DXFs and STEP files when I export individual parts. It beats many other programs opening up files for preview prior to manufacture - No splash screen and small memory footprint make it really fast.
Look forward to final release of v4.
regards
Alex.
9526.185 In reply to 9526.179
Just a short feedback on that issue. It was solved after installing the latest driver version. Perfect!
Joerg
9526.186 In reply to 9526.185
That's great Joerg, thanks for letting me know!
9526.187
I just tried out the v4 beta and I noticed that the right mouse button doesn't cancel actions anymore.
9526.188 In reply to 9526.187
Hi Andre,
That's correct, that's a change to the default behavior discussed previously here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8966.13
You can switch it back to v3 behavior by an option in moi.ini . Go to Options > "Edit .ini file", and find this setting:
[View]
DoRightClickCancel=n
Set it to say =y instead and you should get the old right-click canceling behavior back.
9526.189
On little finding here, is that the viewport goes black after turning my monitors off and on again.
Graphics driver or Moi issue?
Bests,
Morten
9526.190 In reply to 9526.189
Hi Morten, most likely a driver issue. I would recommend checking your video card manufacture's web site to see if there is a newer version you can update to.
9526.191
A simple question: can I install the new beta without having any problem with the already installed old version? I mean can I have both of them installed in the same computer?
9526.192 In reply to 9526.191
The last beta V 4 can be installed without problem on the same computer if you have yet the V 3!
You can even install the alternate demo infinite without save! ;) (V 3)
The previous betas are time limited so don't work any more!
9526.193
Thanks Pilou! : - )
9526.194 In reply to 9526.191
Hi Dimitri, yes like Pilou says above you can install the current v4 beta alongside any other version of MoI. By default they will go into their own separately named install folders and not directly on top of each other.
9526.195
Thanks Michael! : - )
9526.196
Hey all! I hope the ones on a holiday are enjoying it!
Not sure if this is intended, user error, misunderstanding of the tool on my part or a bug, but I will leave it here. The object on the right is the profile of the sweep on the left. When I try to modify a point I get this behavior which I find puzzling :))
EDITED: 24 Dec 2019 by NAMELESS
Size: 1.2 MB, Downloaded: 203 times, Dimensions: 610x509px
Show messages:  1-16  …  117-136  137-156  157-176  177-196  197-216  217-233
