 1-13  …  134-153  154-173  174-193  194-213  214-233
9526.174 In reply to 9526.173
Perfect. Thank you Michael.
9526.175
I also had a look to the new V4 version and like the new functions and options a lot. The new dimension function is very intuitive AND fast in handling.
For information:
I recognized a behaviour I did not had before with the V3. This morning when waking up the WIN10 machine while MOI3D was opened when shutting it down into sleep-mode yesterday, the draw area keeps black with no options to get it re-drawn. All other areas of MOI3D (like menus, etc.) are visible as usual and working. All other Windows program that were opened
during shut down are visible and working. Graphics card is a Quadro K2000.
Greetings,
Joerg
9526.176 In reply to 9526.175
Hi Joerg, thanks for reporting the wake-from-sleep problem. Did the viewports stay black even after doing something that would make them redraw like zooming or panning inside them?
Thanks, - Michael
9526.177 In reply to 9526.176
I think I tried most options to force a re-draw (like zooming, panning, drawing in the dark, minimizing Moi3d-window, maximizing again, etc.). Screen kept black. Restarting MOI of course solved the issue ;o)
Greetz,
Joerg
9526.178 In reply to 9526.177
Hi, i had the same problem with a quadro card (m2000m). I solved it with another driver. Maybe it's some kind of driver issue ?
Moujiik
9526.179 In reply to 9526.177
Hi Joerg, yes it is probably video driver related. If you keep running into it I'd recommend checking on the NVidia web site to see if there is an updated driver available.
The reason you may have not seen this with V3 is that MoI v3 used the Direct3D9 system for connecting to the video card while MoI v4 uses Direct3D11 instead.
9526.180
Thank you for the release, Michael.
How can I avoid dimensions and texts to scale up and down when I zoom in and out the window?
Thank you,
Massimo.
9526.181 In reply to 9526.180
Hi Massimo,
Currently the text is designed to be an annotation that stays the same size on screen no matter what the current zoom level.
There isn't a way to change that right now but I do plan on making an option for model-size dependent text that scales like model geometry.
I will also probably do some additional refinement of the current scale-independent method to allow them to shrink if you are zoomed out a lot. I'm not sure if this refinement will make it in to v4 or not though.
9526.182
Probably been asked before but with the DIMS module will this have a global text size adjustable to the open document. So if your working on large items the dims are relevant to the scale working in that document.
Also when working with other file formats and opening or importing into a new doc is it possible for the MOI to default file name that is came from this action is standard in RHINO and Solidworks to name a few.
EDITED: 26 Jan 2020 by ALEXPOLO
9526.183 In reply to 9526.182
Hi Alex,
The current initial method is that the text is scale independent and stays the same size on screen no matter what the size of your model. So the current dims already solve that problem, they don't need any adjustment depending on whether you are working with large sized models or small sized models.
That's basically why the initial focus is on having scale independent text that is always the same screen size, then you don't have to worry about these kinds of scale issues that you are describing here.
I do plan on having a setting for model scale dependent text as well, I'm not quite sure yet on the specifics of how that will work.
MoI does not do this because .3dm format is the only format that can contain everything that you can create in MoI including stuff like background images for example. So the current file name is only set if you open .3dm format, that way there isn't any chance for there to be data loss if you have created things that do not save to .DXF format for example.
There is a setting in moi.ini that you can set to modify some of this behavior, that's under:
[Settings]
SetNameWhenOpeningAllFileTypes=y
When set, the current file name is set for all file opens not just .3dm files.
9526.184
Thanks for the info thats great and the SETNAME option in the ini is another hidden gem. Moi opens so fast I use it as my default file viewer for DXFs and STEP files when I export individual parts. It beats many other programs opening up files for preview prior to manufacture - No splash screen and small memory footprint make it really fast.
Look forward to final release of v4.
regards
Alex.
9526.185 In reply to 9526.179
Just a short feedback on that issue. It was solved after installing the latest driver version. Perfect!
Joerg
9526.186 In reply to 9526.185
That's great Joerg, thanks for letting me know!
9526.187
I just tried out the v4 beta and I noticed that the right mouse button doesn't cancel actions anymore.
9526.188 In reply to 9526.187
Hi Andre,
That's correct, that's a change to the default behavior discussed previously here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8966.13
You can switch it back to v3 behavior by an option in moi.ini . Go to Options > "Edit .ini file", and find this setting:
[View]
DoRightClickCancel=n
Set it to say =y instead and you should get the old right-click canceling behavior back.
9526.189
On little finding here, is that the viewport goes black after turning my monitors off and on again.
Graphics driver or Moi issue?
Bests,
Morten
9526.190 In reply to 9526.189
Hi Morten, most likely a driver issue. I would recommend checking your video card manufacture's web site to see if there is a newer version you can update to.
9526.191
A simple question: can I install the new beta without having any problem with the already installed old version? I mean can I have both of them installed in the same computer?
9526.192 In reply to 9526.191
The last beta V 4 can be installed without problem on the same computer if you have yet the V 3!
You can even install the alternate demo infinite without save! ;) (V 3)
The previous betas are time limited so don't work any more!
9526.193
Thanks Pilou! : - )
Show messages:  1-13  …  114-133  134-153  154-173  174-193  194-213  214-233
