V4 beta Oct-10-2019 available now
 1-5  …  126-145  146-165  166-185  186-205  206-225  226-233
9526.166 In reply to 9526.165
Maybe the Scale is too big because when you reduce it all works fine !
Scale 0.5
9526.167 In reply to 9526.165
Hi moujiik, yes there's a bug in the text display that will happen if your object has coordinates larger that 2500 units. I've got it fixed for the next beta which I should be able to put out in a few more days.
Thanks, - Michael
9526.168
Michael,
I may have found a bug?
When I do a simple offset to the out side I get extra lines original line is the blue line the offset is the orange line and the red lines are the unwanted lines.
thanks,
Val
EDITED: 11 Jan 2024 by VAL2
9526.169 In reply to 9526.168
Hi Val, yup that's a bug although it's not new for v4 it's also present in v3 and earlier. The bug has to do with the process of extending the offset to make a new sharp point on it. The extension method used is a reflection method and when it makes a long reflected extension that's what makes the kind of crazy excess stuff. I've looked into it a little bit before and I'll take another look but it may be a fairly sensitive thing to mess with right near the end of the beta process so it might need to wait for a bit for a fix.
Thanks, - Michael
9526.170
HI Michael,
Trying to create and PDF with dimensions but they drop out. Any advice welcome.
thanks
Alex.
EDITED: 20 Sep 2020 by ALEXPOLO
9526.171 In reply to 9526.170
Hi Alex,
> HI Michael,
> thanks
> Alex.
Yes exporting of dimensions is not finished up yet, it's probably the last thing that will get finished before the v4 final release is ready.
9526.172
Since it sounds like it could be a while before we are able to export dimensions, is there a way to bind a background color change to a hot key. I like to work with a gray background and would like to be able to quickly change it to white for a screen shot of the dimensions, then back to gray again. I hope that makes sense.
Terry
9526.173 In reply to 9526.172
Hi Terry, if you set up the following on a shortcut key it will switch the background to white, generate a viewport image with the white background and put it on the system clipboard and then reset the background back to its previous value:
script: /* Custom screenshot */ var prev_background = moi.view.viewportBackgroundColor; moi.view.viewportBackgroundColor = 0xFFFFFF; moi.grid.display = false; moi.grid.showXYAxes = false; moi.view.showAxisIcon = false; moi.ui.getActiveViewport().renderToClipboard( 4000, 2500 ); moi.grid.display = true; moi.grid.showXYAxes = true; moi.view.showAxisIcon = true; moi.view.viewportBackgroundColor = prev_background;
Hopefully that will help, let me know if it isn't quite right.
9526.174 In reply to 9526.173
Perfect. Thank you Michael.
9526.175
I also had a look to the new V4 version and like the new functions and options a lot. The new dimension function is very intuitive AND fast in handling.
For information:
I recognized a behaviour I did not had before with the V3. This morning when waking up the WIN10 machine while MOI3D was opened when shutting it down into sleep-mode yesterday, the draw area keeps black with no options to get it re-drawn. All other areas of MOI3D (like menus, etc.) are visible as usual and working. All other Windows program that were opened
during shut down are visible and working. Graphics card is a Quadro K2000.
Greetings,
Joerg
9526.176 In reply to 9526.175
Hi Joerg, thanks for reporting the wake-from-sleep problem. Did the viewports stay black even after doing something that would make them redraw like zooming or panning inside them?
Thanks, - Michael
9526.177 In reply to 9526.176
I think I tried most options to force a re-draw (like zooming, panning, drawing in the dark, minimizing Moi3d-window, maximizing again, etc.). Screen kept black. Restarting MOI of course solved the issue ;o)
Greetz,
Joerg
9526.178 In reply to 9526.177
Hi, i had the same problem with a quadro card (m2000m). I solved it with another driver. Maybe it's some kind of driver issue ?
Moujiik
9526.179 In reply to 9526.177
Hi Joerg, yes it is probably video driver related. If you keep running into it I'd recommend checking on the NVidia web site to see if there is an updated driver available.
The reason you may have not seen this with V3 is that MoI v3 used the Direct3D9 system for connecting to the video card while MoI v4 uses Direct3D11 instead.
9526.180
Thank you for the release, Michael.
How can I avoid dimensions and texts to scale up and down when I zoom in and out the window?
Thank you,
Massimo.
9526.181 In reply to 9526.180
Hi Massimo,
Currently the text is designed to be an annotation that stays the same size on screen no matter what the current zoom level.
There isn't a way to change that right now but I do plan on making an option for model-size dependent text that scales like model geometry.
I will also probably do some additional refinement of the current scale-independent method to allow them to shrink if you are zoomed out a lot. I'm not sure if this refinement will make it in to v4 or not though.
9526.182
Probably been asked before but with the DIMS module will this have a global text size adjustable to the open document. So if your working on large items the dims are relevant to the scale working in that document.
Also when working with other file formats and opening or importing into a new doc is it possible for the MOI to default file name that is came from this action is standard in RHINO and Solidworks to name a few.
EDITED: 26 Jan 2020 by ALEXPOLO
9526.183 In reply to 9526.182
Hi Alex,
The current initial method is that the text is scale independent and stays the same size on screen no matter what the size of your model. So the current dims already solve that problem, they don't need any adjustment depending on whether you are working with large sized models or small sized models.
That's basically why the initial focus is on having scale independent text that is always the same screen size, then you don't have to worry about these kinds of scale issues that you are describing here.
I do plan on having a setting for model scale dependent text as well, I'm not quite sure yet on the specifics of how that will work.
MoI does not do this because .3dm format is the only format that can contain everything that you can create in MoI including stuff like background images for example. So the current file name is only set if you open .3dm format, that way there isn't any chance for there to be data loss if you have created things that do not save to .DXF format for example.
There is a setting in moi.ini that you can set to modify some of this behavior, that's under:
[Settings]
SetNameWhenOpeningAllFileTypes=y
When set, the current file name is set for all file opens not just .3dm files.
9526.184
Thanks for the info thats great and the SETNAME option in the ini is another hidden gem. Moi opens so fast I use it as my default file viewer for DXFs and STEP files when I export individual parts. It beats many other programs opening up files for preview prior to manufacture - No splash screen and small memory footprint make it really fast.
Look forward to final release of v4.
regards
Alex.
9526.185 In reply to 9526.179
Just a short feedback on that issue. It was solved after installing the latest driver version. Perfect!
Joerg
Show messages:  1-5  …  106-125  126-145  146-165  166-185  186-205  206-225  226-233
