V4 beta Oct-10-2019 available now
 1-14  …  75-94  95-114  115-134  135-154  155-174  …  215-233
9526.115 In reply to 9526.111
You're right. It's an issue with the import modules of the 2015 versions of our software. Here's an example of one object that was imported into MOI via step format (the format the client delivers) :
"D_1338_00IAM-00-10S14P/LIC18650-TBD PCM PC: 724189IAM-03-METAL PLATE NIL1:2: 724189IAM-03-METAL PLATE NIL1: D_1314_41IPT-03-METAL PLATE NIL1:1: D_1314_41IPT-03-METAL PLATE NIL1: Volumenkörper1"
As you can see, not only awful long names but a lot of extended chars as well. One is interesting (Volumenkörper1) because its supposed to be Volumenkörper (a german word. Client is german).
Not sure if ö got replaced by ö because of the clients export module or if was translated by MOI on import.
If you can provide a script to remove extended characters, that would be indeed very helpful! Thanks a lot!
Sven
Technical drawing is missing from my education.
I'm going to buy this book. Have to see how much of this MoI Dimensions can do.
Click on the book picture for an extensive preview:
https://www.amazon.com/Technical-Drawing-Engineering-Graphics-15th/dp/0134306414
9526.117 In reply to 9526.115
Hi Sven,
> Client is german).
If it is possible for you to send me the file to test with at moi@moi3d.com I promise to keep it confidential and then I might be able to test with it and find out if the ö got mangled at import or not.
Also I've been meaning to do something about these intolerably long object names. I think when I updated the import libraries to a new major version the names are getting some kind of STEP "product ID" code or something like that appended to their start. Something like that anyway.
No problem, please try setting up the following on a shortcut key, this should remove any non-ascii characters from object names:
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name ) obj.name = obj.name.replace(/[^\x00-\x7F]/g, ""); }
9526.118 In reply to 9526.116
Did you see the link OSTexo posted above:
https://ocw.mit.edu/courses/mechanical-engineering/2-007-design-and-manufacturing-i-spring-2009/related-resources/drawing_and_sketching/
That's a nice short overview.
Message 9526.119 deleted 17 Oct 2019 by SCONSTABLE
9526.120 In reply to 9526.102
>You mean something like having an extra button shown there?
Possibly. I was thinking just having the ability to select "default" or "none" (which would default to the UI font default would suffice.
>That's kind of problematic from a usability standpoint because it gives a lot of weight to the "None" button.
Seems the issue could be resolved by change the verbiage to be something like "reset" or something like that.
>Maybe instead of saying "None (using UI font)..." there I should just show the name of the UI font that's going to be used.
That's what it does now. Before you select a custom font it shows the "None (using UI font).." and after changing it, it shows what the current font is. The issue is there is no way to get it back to the default UI font setting except ot go in and select "Open Sans" and set it to 12pt to get you to the same font and size as the default, But even then, it shows "Open Sans" as the custom font selected.
It seems to me from a consist UI perspective, simply providing a "default" at the top of the font list when you click on the clickable area to select a font, which would reset it to the default UI font and size, would be the best solution.
9526.121 In reply to 9526.113
Thanks for an explanation, Michael.
So it seems when I first heard about these new "Dimensions" I misunderstood them and somehow imagined it will be something like the system in SW/Inventor etc. (probably because I was working in SW for a few years back in the day).
But all clear now. It would be really nice to someday get this feature working just like in apps mentioned before, though :) so fingers crossed!
Love the updated fbx exporter too (especially naming export). Since before this, every time time I changed something in the model and re-exported it to 3DS Max I had to rename all the parts once again (and usually there's like 10-20 of them). And that was a pain in the ass which is now gone, thanks to You.
9526.122 In reply to 9526.121
Hi mantaskava,
I would like that too, but there is a tremendous amount of work involved in doing that. Those other apps you mentioned before come from companies making literally billions of dollars more than me.
So that's a pretty tall order for me as a single person to replicate the work of a billion dollar company that has had a team working on it for 20 years. It would be cool but it's not particularly feasible, there's a vast discrepancy in the amount of resources.
In general I can be more effective by focusing my energy on things that those other companies are not doing. If you need the things that those apps do then it makes sense to use them too if it helps you get your job done.
9526.123 In reply to 9526.117
turned out the non ascii characters wasn't the only problem in that case. I modified your script to also remove slashes and colons. Even then the fbx didn't work. After several hours digging through lists of object names, trying to find any suspicious characters I stopped. Possibly the length of the names was also a problem, I don't know. I changed the script again to remove object names *entirely* and then it worked.
Since I don't absolutely need the object names, I"m happy with that.
Thanks again for your help. Btw the new feature having materials exported in fbx is very useful!
Sven
EDITED: 18 Oct 2019 by SCONSTABLE
9526.124 In reply to 9526.123
Hi Sven, thanks for letting me know what was going on with the FBX import.
Does that mean that you don't need any option for stripping out extended characters from object names then?
I've also taken a look at why the names are so long, it's because there is this property in a "Product name" and that's getting added to the name as well (sometimes twice I guess) like "Product name: component name". I've updated this for the next beta to only get the component name so I think that should help avoid getting tremendously long names. I'll put in an option to have the long names (with duplication removed) if that was useful for someone.
9526.125 In reply to 9526.124
Well, I'd say it's always a good idea to filter them out but thats more from a general perspective. At one point or another they'll cause problems in a pipeline and to be honest, no one needs them.
So it would be a nice feature to have that option, yes. Do I absolutly need it right now? No, because I can alternatively remove names entirely and that's good enough for me.
- Sven
9526.126 In reply to 9526.125
Hi Sven, ok I'll leave that option for stripping extended characters in then.
9526.127
Hi Michael.
Thanks for the recent update.
I have a question about the SubD From File import option.
I was wondering if your implementation was similar to Catmul-Clark and if so, is there an edge weighting option that we can use to tighten up the mesh?
I have a model in modo that is all quads and all verts are merged. No open boundaries.
When I convert to Catmul-Clark subD with not edge weighting I get this result.
Were I want tight lines and or corners, I simply apply edge weighting.
When I import this model into the latest v4 beta I get this result.
This looks very similar to the conversion to Catmul-Clark in modo without the edge weighting.
My question is, is there a way to apply such edge weighting in Moi upon or after import of such a file?
-s
9526.128 In reply to 9526.127
Hi Scooter, yes the sub-d conversion is almost the same as Catmull-Clark, the only differences are at extraordinary vertices.
There isn't currently any way to set the edge weighting in MoI but that is something I want to work on in the future. Additionally the .obj file format does not itself have any method of representing edge weighting so any transfer through .obj format will not preserve edge weighting anyway.
FBX format does have a way to store edge weighting and that's a format that I want to add in the future.
9526.129 In reply to 9526.128
Michael,
I thought the edge weighting could be something like Max's SubDiv Beta 9 script, where one uses a slider.
I'd rather see this for imported OBJ files, as opposed to relying on the ever changing proprietary FBX format.
Thanks for the consideration.
-s
9526.130 In reply to 9526.129
Hi Scooter,
Just a slider after the import does not seem very feasible to me since there isn't any control over what edges are being targeted.
In the future I would like to have it so importing an obj file would result in creating a special sub-d type object in MoI where you could turn on control cage points and move them around, adjust edge weights, etc... For now when there is not the infrastructure in place for making those types of objects it just makes a regular NURBS object.
9526.131 In reply to 9526.130
"... In the future I would like to have it so importing an obj file would result in creating a special sub-d type object in MoI where you could turn on control cage points and move them around, adjust edge weights, etc..."
That, I would like to see. It would take MoI to a whole new level.
9526.132 In reply to 9526.130
That sounds feasible to me Michael and would be much appreciated.
Until then, I'm attempting to have the current importer give me the results I'm looking for.
What I've done is to unweld all of the points of my object, in order to take advantage of the "SubD import options" "Open Boundaries" "Keep Corners"
When I import this file into Moi, it sees that all faces are open boundaries and thus retains the sharp corners.
Then, moi appears to weld the patches back together and a create a Solid for me.
Not certain if this has resulted in a true NURBS object though.
Can you test the attached file and let me know what was created?
-s
9526.133 In reply to 9526.132
Hi Scooter,
Yeah it's a NURBS object, although a kind of oddly structured one with a lot of little surface fragments instead of large smooth surfaces.
9526.134 In reply to 9526.133
Michael,
I build all of our models in a DCC app and occasionally am asked to create an equivalent CAD model.
In the ongoing attempt to convert a quad poly mesh into a CAD model, I thought I was onto something.
Perhaps I'm misunderstanding the whole point of the SubD importer.
Just what should I expect as the result of the import?
Is it just a background mesh to build off of?
Would like to avoid having to completely rebuild it.
-s
Show messages:  1-14  …  55-74  75-94  95-114  115-134  135-154  155-174  175-194  …  215-233
