So it's a bit difficult as I'm thoroughly under NDA but they are draughted build drawings (dimensioned cad drawings) similar to architectural drawings with lineweights, hatches etc.
Not really the same as a cad prog but more funny for the client! :)
I suppose that he must have also TwinMotion for this function! (i must test that)
edit : tested seems client can't measures in the Bim File created like following (visible without Twinmotion)
but if you have measured something that will be visible ! ;) (better than nothing)
(don't forget to load this free TwinMotion 2019 gift before end october! ;) (can be used commercially)
Yeah definitely Michael - my primary aim is to get rid of some of the bloat that goes along with something like Revit - I would really only need the soft for drafting. Rhino is a good call as used so prevalently in this industry it seems but I wouldn't personally use it for drafting probably - DraftSight looks promising!
Rich ::
Depending on how in a hurry you are, I would just wait for Michael's implementation.
I have a feeling it will be the simplest option for that kind of job.
Keeping revit for the moment would save the time/frustration involved in learning and using another software.
If you have even a "low tablet" with not many hard memory you can use something like https://www.realvnc.com/
and like this run any programs on your tablett! ;)
It's truely amazing to run Moi3D like this!
You can also put an OTG connector for put a mouse 3 button + wheel on your Tablet ;)
(exists of course all made! ) 2$
