Help, How can I desing this ring
All  1-3  4-6
9519.4
Hi There
you can try it this way , the OV are just extruded and the LE are swept with the half round profiles.
but the results are a bit random where the end letters sweep to the outside profile
if you used 2 sweep lines you may be able to control them
cheers
shayne
9519.5 In reply to 9519.4
Shayne - I like your approach. It looks like you forgot to Boolean Diff the ring with the inside diameter circle, which will make the ring wearable by removing material under the L & E. I did that and was able to Boolean Union the entire ring. Looks nice.
9519.6 In reply to 9519.5
2 sweep rails tidys it up without having to boolean out the inside
rebuild on the D section to match the number of points on the top letters also gives a better sweep
cheers
shayne
Show messages: All  1-3  4-6
