Adding "Info" button and documentaion for a node.
All  1-12  13-17
9518.13 In reply to 9518.12
So, For example, adding RussianStrings.txt to the MoI ui folder would add Russian to the Options button. (?)
Guess there has not been much interest... Maybe Max would provide RussianStrings.txt for MoI, if someone requested?
9518.14 In reply to 9518.4
At this time, the node info button is NOT working for the light color scheme.
I thing that basicFunctions.js ( I think Karsten wrote it?), applies to index.html, but NOT to index.html?scheme=Light?
The path to basicFunctions.js is %APPDATA\nodeeditor\node\extensions\libs\
Still puzzled,
9518.15 In reply to 9518.14
So using the Info menu with light version was solved by Karsten back in March.
I forgot, and also lost the correction after my SSD failure a month or 2 ago.
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1398
So I made Karstens modification to basicFunctions.js so that the Info *.html box will appear in Light version of nodeeditor.
(commented out older code.)
(Backup of basicFunctions.js saved as basicFunctions.BAK, NOT basicFunctionsOld.js.)
EDITED: 22 Oct 2019 by BEMFARMER
Updating the Info *.html file for a node is not working.
The old *.html Info file keeps coming up in nodeeditor, even if the file is deleted.
It was working just fine a day ago... I only made a few minor changes...
Maybe a cache need clearing?
Reboot of computer did not help.
Closing MoI4beta did not help.
EDITED: 25 Oct 2019 by BEMFARMER
9518.17 In reply to 9518.16
So if an old info *.html gets Stuck with the corresponding node, Press Alt+New on the nodeeditor screen to clear the old info .html file.
This must be some kind of correctable bug in the info code in a node?
Closing a node should sever its tye to its info *.node?
Is there a superior way to code the info files than with .html?
Show messages: All  1-12  13-17
