MoI tutorials
 1-2  3-22  23-26
9508.23 In reply to 9508.16
Hi Bartosh,
> Is it possible to do some deformation gradually in MoI like Modo ones with linear falloffs?
Not really, no - if you need that kind of deformation you would probably want to use a polygon modeler for that project rather than a CAD program.
> Is it possible in MoI to align curve points linear to get straight line without deleting points?
You can use the Transform > Align command to make a set of points lined up in a vertical or horizontal line. But if you want to work by editing points of a 3D shape, that's something you would be better off doing in a polygon modeling program instead of a CAD program too.
9508.24
Thanks Pilou and Michael for your tips.
9508.25 In reply to 9508.3
Hi Frenchy,
"Falloff" in Modo has to do the amount of influence you have when you push/pull polygons. Example, look at this image. The bottom bump has a greater "falloff."
Size: 570.2 KB, Downloaded: 30 times, Dimensions: 566x230px
9508.26 In reply to 9508.25
Ah ok a sort of area of influence ! :)
Show messages:  1-2  3-22  23-26
