MoI tutorials
 1  2-21  22-26
9508.22 In reply to 9508.14
Hi Bartosh,
> @Micheal: You`ve replied in some forum thread that ViaCAD has got better filleting engine. Should I understood
> it that I should buy this soft ass addition for MoI and I won`t be forced to fixed jagged line like this? Do you still
> hold your statement about quality of ViaCAD fillet engine?
Definitely ViaCAD's fillet engine is much better than MoI's but it is not likely to be able to fillet a messy object like that either. Filleting in CAD is just too complex of an operation and it is more designed around having accurate geometry to work with not messy geometry.
I tested your particular file in the old version of ViaCAD I have here and it gives this error:
> Is this same with blending?
I don't think ViaCAD has a surface blend function like MoI's.
9508.23 In reply to 9508.16
Hi Bartosh,
> Is it possible to do some deformation gradually in MoI like Modo ones with linear falloffs?
Not really, no - if you need that kind of deformation you would probably want to use a polygon modeler for that project rather than a CAD program.
> Is it possible in MoI to align curve points linear to get straight line without deleting points?
You can use the Transform > Align command to make a set of points lined up in a vertical or horizontal line. But if you want to work by editing points of a 3D shape, that's something you would be better off doing in a polygon modeling program instead of a CAD program too.
9508.24
Thanks Pilou and Michael for your tips.
9508.25 In reply to 9508.3
Hi Frenchy,
"Falloff" in Modo has to do the amount of influence you have when you push/pull polygons. Example, look at this image. The bottom bump has a greater "falloff."
Size: 570.2 KB, Downloaded: 30 times, Dimensions: 566x230px
9508.26 In reply to 9508.25
Ah ok a sort of area of influence ! :)
Show messages:  1  2-21  22-26
