scripts not working
All  1-5  6-7
9498.6 In reply to 9498.5
For this forum thread I have some question:
Whats the difference between Moi V4 with sub-d obj importing and converting them to Nurbs and ImportObj script?
Down below attached picture of the obj file imported with ImportObj script.
As I do understand with sub-d import and converting to Nurbs would not be so many polygonal planes on the cup im I right ? And loading obj. file time will be much more shorter?
A few days before i bought Moi v3 and want to stick to that, but if many new cool features a better in V4 i will upgrade if needed.
Thank you for an answers.
K.
Size: 114.5 KB, Downloaded: 49 times, Dimensions: 978x747px
9498.7 In reply to 9498.6
Hi Konni, the new v4 sub-d importer importer can make larger surfaces and also has a higher level of smoothness between surfaces.
It is meant though for importing not just any kind of .obj file, it's only meant for loading a file that has been set up for subdivision smoothing.
If you purchased MoI v3 within the last year then you will be getting a free upgrade to v4 when it is out, so I'd recommend using v4 now. You can get the v4 beta at http://moi3d.com/beta.htm .
Show messages: All  1-5  6-7
