Bug with Silhouette command?
All  1  2-6
9491.2 In reply to 9491.1
Thanks Brian, it is definitely a bug but quite difficult to fix. The problem is occurring at the poles, one pole has that gap and the other pole has 45 little tiny curves. You can select the little curves by doing a window select.
The pole or "singularity" spot of a surface tends to be a particularly sensitive area for numeric processing.
9491.3 In reply to 9491.2
Thank you Michael. It is of minor importance to myself.
I was wondering if Solids++ is evolving?
- Brian.
9491.4 In reply to 9491.3
I don't know what their longer range plans are but no it hasn't been for a while.
9491.5 In reply to 9491.4
Michael & Brian,
There does seems to be development happening in recent times.
According to IntegrityWare website, they have been "more than
doubling the size of the company over the past two years."
Does Solids# represent the evolution?
https://www.integrityware.com/SolidsSharp.html
Is this a kernel that MoI3d could transition to?
They have also developed a mesh to NURBS converter: "SubD-NURBS"
http://www.integrityware.com/subdnurbs.html
9491.6 In reply to 9491.5
Hi James,
Sounds like it's a port of Solids++ to the C# programming language.
No, MoI does not use C#.
But maybe they will be developing Solids++ and Solids# in parallel, I don't know.
Show messages: All  1  2-6
