Exploration of Scripting in MOI
All  1-5  6-8
9490.6 In reply to 9490.5
That information was very useful. Thank-you so much.
Have setup hotkeys for the scripts that are working thus far.
Unsuccessfully trying to Imitate your " Include Edge Option " in the Silhouette Script.
Currently cannot get the objects edges silhouette to happen correctly.
Hoping to avoid using the sidepane silhouette icon and having to select "Include edges" checkbox.
Looking for easier solution to script that "Include Edge Option" .
Any tips on what steps to take?
P.S.
Moi has been great for designing structures. "Quickly". Although I haven't used it for any piping designs as of yet, but it looks like a snap.
Dave
Size: 1009.5 KB, Downloaded: 55 times, Dimensions: 1364x807px
9490.7 In reply to 9490.6
So far coming out of this endeavor to create this proposed script is...
Combining the freehand from two axis planes, loft and use this
well, create a terrain map on an object?
Size: 356.2 KB, Downloaded: 38 times, Dimensions: 806x709px
Size: 428.6 KB, Downloaded: 31 times, Dimensions: 859x745px
9490.8 In reply to 9490.6
Hi Dave, that's great that you're making good progress!
So for include edges the way to figure out how to replicate that in a script is to first look at the Silhouette.htm file and find the "Include edges" button which is this:
<moi:CheckButton id="includeedges"><moi:Text textid="Include edges checkbox"/></moi:CheckButton>
The key thing that you're looking for is the id value. So then go to the Silhouette command script file (Silhouette.js) and search for includeedges, which is this:
ui.bindUIToInput( 'includeedges', 'value', factory.getInput(4) );
So what the regular command is doing there is making a link between the includeedges checkbox UI controls's value property and the silhouette factory's input with index 4.
In your script you'd want to do something like factory.setInput( 4, true ); to turn it on.
Some UI will set up a binding like that and others will look for a UI event of that id value being triggered if they need to do other stuff in addition to just setting a value on the factory.
Hope that helps!
Show messages: All  1-5  6-8
