Boolean Difference
All  1-5  6-11
9485.6 In reply to 9485.5
As soon as the first volume is not auto-intersected all works as supposed to be! ;)
Maybe can you try in other progs (freeCad... Fusion 360...)for see if you obtain the same result...
EDITED: 6 Sep 2019 by PILOU
9485.7 In reply to 9485.4
Thank-you Michael.
MOI is amazing. Inspirational. Intuitive and easy to use. The first thing that caught my eye towards using this great Software was how simple it was to swap and design through split views. It is becoming easier to navigate.
You have answered my question;
(self intersecting solids, the "skin" of a solid will tend to cause volume oriented calculations like booleans to fail)
Is there a way to skin such an object or cover just the outside of the object, lending a way to achieve the cross-section?
Script perhaps?
Thank-you
Dave
9485.8 In reply to 9485.7
Maybe try with two donuts which overlab a little, rather than helix?
9485.9 In reply to 9485.7
Hi Dave,
That would be pretty difficult. Probably the easiest way to get a good solid for your case here is to build it out of 2 halves so that each piece only intersects the other and not itself. Then they can be combined with boolean union.
Here's what that looks like, also see attached 3DM file where the boolean difference should work now:
Super tricky! Bravo!
9485.11 In reply to 9485.9
That method works.
Selection of profile is important.
Self intersecting Bad.
Thank-you.
Dave
Show messages: All  1-5  6-11
