"style select" within a solid subset.
All  1-7  8-20
9477.8 In reply to 9477.7
Thanks Neil, yes I think I understand now. Please try this script, does it do what you need:
script: /* Expand selection over same styles on sub objects */ var styles = new Array(); var parents = new Array(); var sel = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < sel.length; ++i ) { var obj = sel.item(i); if ( obj.selected ) { styles[obj.styleIndex] = true; } if ( !obj.isTopLevelObject ) { var par = obj.getTopLevelParent(); parents[par.id] = par; } } for ( var i in parents ) { var subobjs = parents[i].getSubObjects(); for ( var j = 0; j < subobjs.length; ++j ) { var subobj = subobjs.item(j); if ( subobj.isFace && styles[subobj.styleIndex] ) subobj.selected = true; } }
9477.9 In reply to 9477.8
Michael your a legend !!!!!!
it work perfect!!!!!!
thank you so much!!!
9477.10 In reply to 9477.9
That's great Neil, you're welome!
does this old one for V2 "On objects" works also on V3? (seems yes but want to be sure! :)
script: /* Extend the selection of objects with the same style */ var objects = moi.geometryDatabase.getObjects();var styles = new Array();for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( obj.selected ) styles[obj.styleIndex] = true; } for ( var i = 0; i < objects.length; ++i ) { var obj = objects.item(i); if ( styles[obj.styleIndex] ) obj.selected = true; }
EDITED: 25 Aug 2019 by PILOU
9477.12 In reply to 9477.11
Hi Pilou, yes that one works ok on v2, v3, and v4.
else i have a bug with the "sub-object" ?
else does this normal ?
after boolean Diff of a blue sphere from a Red Cube i have the "generative arc circle" on the result ?
So 2 "facetts" on the result!
9477.15 In reply to 9477.13
It looks like that's from your changes with editing the comment part of the code, script code can only have ascii characters in it.
9477.16 In reply to 9477.14
That's a normal result if that was where the closing "seam" edge of the sphere was at.
9477.17 In reply to 9477.16
"Seam's sphere" yes it's :)
So i suppose to rotate it before boolean Diff can solve this little disturb...
else
I correct the "sub object bug" in pasting your "English script" inside the "ShortCut" Moi editor and change comments directly !
(even with accents)
That works! :) I had previously copy / past the text from another prog... maybe this explain that! :)
9477.18 In reply to 9477.16
hi Michael,
can you make another script to do the same for edges that get assigned a style.
9477.19 In reply to 9477.18
Hi Neil, re:
Sure, please give this one a try:
script: /* Expand selection over same styles on edge sub objects */ var styles = new Array(); var parents = new Array(); var sel = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < sel.length; ++i ) { var obj = sel.item(i); if ( obj.selected ) { styles[obj.styleIndex] = true; } if ( !obj.isTopLevelObject ) { var par = obj.getTopLevelParent(); parents[par.id] = par; } } for ( var i in parents ) { var subobjs = parents[i].getSubObjects(); for ( var j = 0; j < subobjs.length; ++j ) { var subobj = subobjs.item(j); if ( subobj.isEdgeCurve && styles[subobj.styleIndex] ) subobj.selected = true; } }
9477.20 In reply to 9477.19
nailed it thank you!
Show messages: All  1-7  8-20
