Elephant Repository
 1-18  …  59-78  79-98  99-118  119-138  139-158  …  499-503
Big Section "Curve" in French done! :)
Now Section "Objects"
Clone done (English French)
http://moiscript.weebly.com/objects.html
Node Selected (English French)
Node Get by Name (English French)
Not yet Updated so OutPut = "--"
EDITED: 6 Sep 2019 by PILOU
Node Get by Style (English French) (sorry I don't why Styles are listed in French on the English Elephant version!!! )
Again in the fog! :)
How to extract "Points" from the OBJToArray Point for see them ?
No yet result with the "Extract"...so try that but...
ConvertPts don't want to show them! (orange square! :(
Before the light of the ObjToArray :) (possible i make a missunderstanding of this Node)
here the last Node BoundingBox of the Object section (English French)
Global view of the Native Nodes
Useful for the Input / OutPut colors! ;)
ObjToArray is totally mysterious for me!
And surrely ConvertPoint! :)
(Selected (0) is normal I made the ScreenShot between 2 tests )
How Extract all from a selection in one pass ?
EDITED: 7 Sep 2019 by PILOU
9476.107 In reply to 9476.106
Selected > ObjtoArray > extractPts > Output
9476.108 In reply to 9476.106
PinkDot represent pointarray class, and contain many properties, including "raw" points, e.g.(x,y,z), AND frames and scales(?) and angles...
GoldDot points are MoI's geometry form of points, which can be added to the geometry database and displayed in MoI. (Object Lists)
GoldDot points can have styles, names, etc.
EDITED: 13 Sep 2019 by BEMFARMER
<<Selected> ObjtoArray > extractPts > Output
I have a cube selected
Not yet working! (square orange) and not sure that takes all points...(maybe also i don't use good nodes after the Extract)
9476.110 In reply to 9476.109
This is working. Maybe right click on Selected and Update. The extractPts is in the Objects2 node
EDITED: 17 Jan 2021 by WAYNEHILL5202
9476.111 In reply to 9476.110
New test only one point (before reading your last post)
Ah OK Cool! you pass not by the "Array" :)
So what is the "Pink Array" of the "ObjTo Array" ?
Just a little Thing : The "ExtractPts" is not in the Native Nodes!!!
I am only on the Native Nodes for the moment! ;)
So maybe that is not possible with only Native Nodes ?
And always want to know what is exactly the Pink "Array" of the Native Node "ObjToArray" :)
More easy :)
Node Loft (English French)
http://moiscript.weebly.com/construct.html
Node Sweep (English French)
Node Extrude ( English French)
New little blockage! I stay on a Flat land! :)
Surely trivial but what is the "Frame" inside the Revolve Node and how to use it?
Of course I can rotate first my Profil... but i want to know the use of this mysterious "Frame"! :)
More easy :)
Node Boolean Diff (English French)
9476.118 In reply to 9476.116
Hi Pilou, a frame is an origin point and 3 direction vectors which together defines a 3D coordinate system, like this:
Probably your case there will use the z axis of the frame as the axis of revolution.
Show messages:  1-18  …  39-58  59-78  79-98  99-118  119-138  139-158  159-178  …  499-503
