Elephant Repository
 1-9  …  50-69  70-89  90-109  110-129  130-149  …  490-503
9476.90 In reply to 9476.89
Vertikal is Max ! ;)
<< Pink pointarray inputs : what is the name of this node (if it's a native one)
Polyline has no case for input list of something
EDITED: 4 Sep 2019 by PILOU
9476.91 In reply to 9476.88
For example:
Use Point node object output, as input to ObjToArray.
Use 3 Progression nodes with different settings, as input to Point node x, y, z.
Sorry I am in total foggy mood! :)
Say I draw 4 Points : how to transform them in Polyline or Curve ?
(or Maybe Nodes Polyline or Curve is not made for that ?
My OutPut stays desesperately "orange" even with hundred of tests/errors! :)
PS and how gives the good order of them ?
OK I have the curve! :)
It's more problematic for the Polyline : problem of order of points!
OK I have the Polyline also! :)
Maybe Node "MovePoint" will be more simple with dx,dy,dz =0 than TransformPts
Not sure if all that is very orthodox but that works! :)
Order of points is good when you click one by one for select them for a few selection
Many more problematic when you have hundred of them!
Very very mysterious!!!
Now that works like that must be! No need to insert an additional Node! :)
Added Polyline (English)
http://moiscript.weebly.com/curves.html
Ok Section Curves (13 items) in English is done...so now the French one...will be easier and faster! :)
Big suspense for the Next Section ! :)
Big Section "Curve" in French done! :)
Now Section "Objects"
Clone done (English French)
http://moiscript.weebly.com/objects.html
Node Selected (English French)
Node Get by Name (English French)
Not yet Updated so OutPut = "--"
EDITED: 6 Sep 2019 by PILOU
Node Get by Style (English French) (sorry I don't why Styles are listed in French on the English Elephant version!!! )
Again in the fog! :)
How to extract "Points" from the OBJToArray Point for see them ?
No yet result with the "Extract"...so try that but...
ConvertPts don't want to show them! (orange square! :(
Before the light of the ObjToArray :) (possible i make a missunderstanding of this Node)
here the last Node BoundingBox of the Object section (English French)
Global view of the Native Nodes
Useful for the Input / OutPut colors! ;)
ObjToArray is totally mysterious for me!
And surrely ConvertPoint! :)
(Selected (0) is normal I made the ScreenShot between 2 tests )
How Extract all from a selection in one pass ?
EDITED: 7 Sep 2019 by PILOU
9476.107 In reply to 9476.106
Selected > ObjtoArray > extractPts > Output
9476.108 In reply to 9476.106
PinkDot represent pointarray class, and contain many properties, including "raw" points, e.g.(x,y,z), AND frames and scales(?) and angles...
GoldDot points are MoI's geometry form of points, which can be added to the geometry database and displayed in MoI. (Object Lists)
GoldDot points can have styles, names, etc.
EDITED: 13 Sep 2019 by BEMFARMER
<<Selected> ObjtoArray > extractPts > Output
I have a cube selected
Not yet working! (square orange) and not sure that takes all points...(maybe also i don't use good nodes after the Extract)
Show messages:  1-9  …  30-49  50-69  70-89  90-109  110-129  130-149  150-169  …  490-503
