Elephant Repository
1-7
48-67
68-87
88-107
108-127
128-147
488-503
Frenchy Pilou (PILOU)
4 Sep 2019 (88 of 503)
9476.88
Yes I am totally agree with you but the problem is that i don't find the good "native" Nodes for that! :)
(simple way like that or more complex)
I must miss something trivial!
EDITED: 4 Sep 2019 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
bemfarmer
4 Sep 2019 (89 of 503)
9476.89
In reply to
9476.81
So Green inputs may have default values in the info window(?) Pink pointarray inputs do not have such default values in the info window (?)
Also Vertikal should be changed to Vertical :-)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
4 Sep 2019 (90 of 503)
9476.90
In reply to
9476.89
Vertikal is Max ! ;)
<< Pink pointarray inputs : what is the name of this node (if it's a native one)
Polyline has no case for input list of something
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
bemfarmer
4 Sep 2019 (91 of 503)
9476.91
In reply to
9476.88
For example:
Use Point node object output, as input to ObjToArray.
Use 3 Progression nodes with different settings, as input to Point node x, y, z.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
4 Sep 2019 (92 of 503)
9476.92
Sorry I am in total foggy mood! :)
Say I draw 4 Points : how to transform them in Polyline or Curve ?
(or Maybe Nodes Polyline or Curve is not made for that ?
My OutPut stays desesperately "orange" even with hundred of tests/errors! :)
PS and how gives the good order of them ?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
4 Sep 2019 (93 of 503)
9476.93
OK I have the curve! :)
It's more problematic for the Polyline : problem of order of points!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
4 Sep 2019 (94 of 503)
9476.94
OK I have the Polyline also! :)
Maybe Node "MovePoint" will be more simple with dx,dy,dz =0 than TransformPts
Not sure if all that is very orthodox but that works! :)
Order of points is good when you click one by one for select them for a few selection
Many more problematic when you have hundred of them!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
4 Sep 2019 (95 of 503)
9476.95
Very very mysterious!!!
Now that works like that must be! No need to insert an additional Node! :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
4 Sep 2019 (96 of 503)
9476.96
Added Curve (English)
http://moiscript.weebly.com/curves.html
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
4 Sep 2019 (97 of 503)
9476.97
Added Polyline (English)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
4 Sep 2019 (98 of 503)
9476.98
Ok Section Curves (13 items) in English is done...so now the French one...will be easier and faster! :)
Big suspense for the Next Section ! :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
6 Sep 2019 (99 of 503)
9476.99
Big Section "Curve" in French done! :)
Now Section "Objects"
Clone done (English French)
http://moiscript.weebly.com/objects.html
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
6 Sep 2019 (100 of 503)
9476.100
Node Selected (English French)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
6 Sep 2019 (101 of 503)
9476.101
Node Get by Name (English French)
Not yet Updated so OutPut = "--"
EDITED: 6 Sep 2019 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
6 Sep 2019 (102 of 503)
9476.102
Node Get by Style (English French) (sorry I don't why Styles are listed in French on the English Elephant version!!! )
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
6 Sep 2019 (103 of 503)
9476.103
Again in the fog! :)
How to extract "Points" from the OBJToArray Point for see them ?
No yet result with the "Extract"...so try that but...
ConvertPts don't want to show them! (orange square! :(
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
6 Sep 2019 (104 of 503)
9476.104
Before the light of the ObjToArray :) (possible i make a missunderstanding of this Node)
here the last Node BoundingBox of the Object section (English French)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
6 Sep 2019 (105 of 503)
9476.105
Global view of the Native Nodes
Useful for the Input / OutPut colors! ;)
My Moi French Site
My MagicaVoxel Gallery
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
7 Sep 2019 (106 of 503)
9476.106
ObjToArray is totally mysterious for me!
And surrely ConvertPoint! :)
(Selected (0) is normal I made the ScreenShot between 2 tests )
How Extract all from a selection in one pass ?
EDITED: 7 Sep 2019 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
wayne hill (WAYNEHILL5202)
7 Sep 2019 (107 of 503)
9476.107
In reply to
9476.106
Selected > ObjtoArray > extractPts > Output
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
28-47
48-67
68-87
88-107
108-127
128-147
148-167
488-503
