Elephant Repository
 1-13  …  34-53  54-73  74-93  94-113  114-133  …  494-503
Added Node Circle (English)
http://moiscript.weebly.com/curves.html
EDITED: 3 Sep 2019 by PILOU
Added Node Rectangle (English)
I have some troubles with the Nodes Curve, Polyline! :)
Added Arc Center (English)
Added Circle Dia (English)
Curiously there is not Input inside the Info Panel!
EDITED: 4 Sep 2019 by PILOU
Added Circle 3 Pts (English) Input datas only by Nodes ! Not Possible by Info Panel !
Added Ellipse Center (English)
Added Ellipse 3 Pts (English)
Maybe a little glitch on the "Z" Point drawing? (not on the ellipse perimeter! )
I am blocked with the Nodes Curves & Polylines for Input datas ! ???
If you have some lights about that! :)
9476.86 In reply to 9476.85
Look at the curves.js file for the geometry definitions.
// Curve
function Curve()
this.addInput("In","pointarray");
this.addOutput("Out","objectlist");
this.properties = { mode:["Curve", "Curve", "Interpcurve"], closed:["No", "No", "Yes"]};
// Polyline
function Polyline()
this.properties = {closed:["No", "No", "Yes"]};
Wayne
EDITED: 4 Sep 2019 by WAYNEHILL5202
9476.87 In reply to 9476.85
The 3 colours of wires and connectors (inputs & outputs) represents the 3 data types:
GREEN = number data (numbers or numArrays)
PINK = point data (points or pointArrays)
YELLOW = objects (curves, surfaces or bReps)
So Curve & polyline nodes inputs are PINK and hence point arrays (minimum length of 2)
Hope this makes sense.
PS Keep up the good work.
EDITED: 4 Sep 2019 by JFH
Yes I am totally agree with you but the problem is that i don't find the good "native" Nodes for that! :)
(simple way like that or more complex)
I must miss something trivial!
9476.89 In reply to 9476.81
So Green inputs may have default values in the info window(?) Pink pointarray inputs do not have such default values in the info window (?)
Also Vertikal should be changed to Vertical :-)
9476.90 In reply to 9476.89
Vertikal is Max ! ;)
<< Pink pointarray inputs : what is the name of this node (if it's a native one)
Polyline has no case for input list of something
9476.91 In reply to 9476.88
For example:
Use Point node object output, as input to ObjToArray.
Use 3 Progression nodes with different settings, as input to Point node x, y, z.
Sorry I am in total foggy mood! :)
Say I draw 4 Points : how to transform them in Polyline or Curve ?
(or Maybe Nodes Polyline or Curve is not made for that ?
My OutPut stays desesperately "orange" even with hundred of tests/errors! :)
PS and how gives the good order of them ?
OK I have the curve! :)
It's more problematic for the Polyline : problem of order of points!
Show messages:  1-13  14-33  34-53  54-73  74-93  94-113  114-133  134-153  …  494-503
